» Sponsors
» Sponsors
Old 09-13-2009, 08:42 AM   #1 (permalink)
Date registered: Oct 2008
Vehicle: A160 Avantgarde
Beware of corrosion!
Mercedes-Benz introduced the 30 years corrosion guarantee, but this does not mean that our A class is immune for corrosion problems.
If your car has been serviced even once at a unauthorized garage, and the car is over 4 years old, you're probably out of guarantee, and this means that you have to repair corrosion problems at your charge.
My car has already been treated against corrosion in Germany as 6 years old, free-of-charge according to the guarantee, but I'm so sorry to see that they did a really bad job.
After a couple of years, the corrosion was back again, and moreover in different parts - also the fuel tank, kindly replaced by my local MB dealer. Mycar is now 10 years old.
In order to avoid this sad corrosion troubles please check the most sensitive parts:
  1. Front doors upper hinges.
    This is a W168 known weakness. These alluminium parts corrode from inside, causing the doors to move some millimeters upwards. The hinges must be replaced (hinges must be painted, if bought directly from MB).
  2. Welding behind the fuel filler flap.
    The welding is exposed to corrosion because of the rain/water that remains inside on the horizontal surface.
    Look at the picture:
  3. Door bendings/weldings, below corners.
    These weldings are very sensitive to water. Look at the picture for the front door:
    and back door:
  4. Weldings in the substructure, especially behind the side sills.
    It's a good idea to inspect the condition of all the weldings - it might be a sad surprise. My MB dealer has never inspected those parts, and I'm sure it's the customer duty to pay attention to the problem.
    Look at these pictures:
    The last picture shows the condition before I started to repair the rust:
Giuggio is offline   Reply With Quote
Old 09-16-2009, 01:08 AM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
I have advocated spraying the underside of the car and vulnerable points with duck oil it's clear, easily applied and available at Halfords in the UK not cheap but then nor is getting corrosion sorted out.
lofty is offline   Reply With Quote
Corrosion repaint profi W204 C-Class 2 04-14-2009 08:57 PM
Beware CLK 55 Owners, Beware Williams707 W208 CLK Class 11 10-26-2007 09:04 AM
corrosion warranty W77 General Mercedes-Benz 1 12-13-2004 03:22 PM
Corrosion AL-Sayegh W163 M-Class 8 06-14-2004 11:45 PM
corrosion bud neutron R170 SLK Class 3 03-15-2002 09:46 PM
