unless the engine is running on all four plugs you will get vibration and of course low revs the engine will have no pull andd will stall easily .
Remove the ignition module and make sure its totally dry, if you know how or can follow guidence then remove the plugs, make sure they are clean and replace It may well be that this condition which i suspect is caused by dampness getting into the system may clear when the car gets warm only time will tell.
if you do have to visit the garage there is every chance MB will tell you it's the MAFS sensor , if that is the case DO NOT leave it with them to repair it will cost between £1200-1400 for a new ecu should this be the cause then it can be repaired for a 1/4 of that price and you will get a 15% discount if you mentioon my site
But first things first see if you can get the car diagnosed see what ythe problem is.
Hopefully you can now come back and say it's sorted itself out.
http://www.aclassinfo.co.uk/mypage.1.htm
