» Sponsors
» Sponsors
Old 07-24-2009, 07:51 AM   #1 (permalink)
Date registered: Dec 2007
A140 coolent change
I have had my a140 51 reg for two years...should I change the coolent?and if so what quantity and type of coolent do I require? Is it a simple job, as unplugging a pipe, drain the radiator and refil?
any kind help would be appraciated.
thanks
shabir is offline   Reply With Quote
Old 07-25-2009, 07:23 AM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
I again refer you to my site ,there are most things there you need to know, look through the index select the page and there you will find a mine field of information.
just go :- http://www.aclassinfo0.co.uk/mypage1.htm
You can only take the horse to the water you can't make him drink!
lofty is offline   Reply With Quote
A140 plug change csturnbull W168 A-Class 6 01-18-2009 01:46 PM
Coolent Level? Type of Coolent Tri-Star W203 C-Class 10 08-27-2008 01:38 PM
coolent sencer gravel W163 M-Class 5 11-18-2007 02:44 PM
coolent change. jabus38 W163 M-Class 22 11-26-2006 09:59 AM
Losing Coolent sss11 W126 S,SE,SEC,SEL,SD,SDL Class 17 05-23-2006 04:56 PM
