» Sponsors
» Sponsors
Old 07-15-2009, 04:36 AM   #1 (permalink)
Date registered: Jul 2009
A160's cold engine starting problem
Hello,
I have following problem while starting A160/1999 (petrol, manual transmission):
1. Engine starts normally, idling in a condition.
2. About 1.5…2 seconds after starting idling goes low until about 400 rpm.
3. After that engine either stops or idle increases to its norm.
Described problem's precondition: first starting, true cold engine (car switched off/stopped more than 4-5 hours ago), outside temperature is more than about 15°C/59°F. In all other cases described problem is not exist, also in the case if car is restarted immediately.
Could anybody help? Thanks a lot in advance.
Note: MAFS was repaired one year ago. Car's ECU diagnostic test has no information/references about this failure.
vipe is offline   Reply With Quote
Old 07-16-2009, 08:44 AM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
Have you changed the fuel filter at the correct periods, dirty fuel filter can play havoc with slow running. will also burn out the pump.
Also please read my post re-MAFS repairs problems have come to light where one company has been modifying the unit which is now causing a number of problems including water damage.
Lofty also my page 38 which will give you full details .
http://www.aclassinfo.co.uk/mypage.38.htm
lofty is offline   Reply With Quote
Old 07-16-2009, 05:27 PM   #3 (permalink)
Thanks Lofty, but fuel filter only on own half way - was changed 2 years/ 20000 miles ago,
and MAFS repaired by ECU Testing.com.
Old 07-17-2009, 05:04 AM   #4 (permalink)
lofty's Avatar
Well that's two items you can discount and 'ecu testings' repairs are OK.
Starting problem and stutter when cold. bielefeld280se W126 S,SE,SEC,SEL,SD,SDL Class 15 10-06-2009 04:08 AM
Problem with cold starting mrankovic W211 E55 AMG, E63 AMG 3 06-02-2005 10:18 PM
Cold Starting Problem Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 3 12-21-2004 01:42 PM
cold starting problem hakkatil General Mercedes-Benz 4 09-27-2004 01:15 PM
300TE 24 cold starting problem Guest (MBNZ) W124 E,CE,D,TD Class 2 01-31-2002 09:44 AM
