» Sponsors
» Sponsors
Old 06-25-2009, 04:48 AM   #1 (permalink)
Filip1981pl's Avatar
Date registered: Apr 2009
Vehicle: Mercedes 500 SL from 1991, A140, Volvo V70
Engine Noise
Hi
I have a problem with engine noise please see the youtube clip. If sombody know if it denger too drive withe this sound...or how to repair this??
regards
filip
Filip1981pl is offline   Reply With Quote
Old 07-17-2009, 05:10 AM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
Have you checked the poly V belt pulley bearings, you will need to remove the belt to test them but as it rev related I would supect something in that area.
For more detail see my page 57
Bert Rowe's-mercedes-Benz 'A'-class info. Poly 'V' Belt replacement, Crankshaft pulley wheel problems.
lofty is offline   Reply With Quote
Old 07-17-2009, 01:01 PM   #3 (permalink)
hello lofty
Yep i check the V belt. I tak off it and start the engine and the noise is this same.
Old 07-18-2009, 02:10 AM   #4 (permalink)
lofty's Avatar
Have you managed to get MB or a garage to listen to the noise, I certainly don't like what I'm hearing if you have isolated the water pump, alternator, air con compressor pulley bearings which you did by removing the belt then this is something more serious, any signs of burning oil, water in the oil , oil in the coolant reservoir? problems starting?
Old 07-18-2009, 07:17 AM   #5 (permalink)
no probllems at all car is runnig normla only this noise
Old 07-18-2009, 09:14 AM   #6 (permalink)
lofty's Avatar
Well there has got to be reason why the noise is there but sorry i can't help, how long ago since you changed the oil? as your aware normally the 'a class oil stays pretty clean is yours OK.
Even though the car is running OK I would try and get it checked out you obviously realise this or you wouldn't have asked for help.
Old 07-18-2009, 11:30 AM   #7 (permalink)
when i bougt this car engin oil was very bad and the noise was less noist becouse oil was very sticky. when i change for mobile one 0W-40 the noise was louder..
thanks for help
Old 07-18-2009, 02:08 PM   #8 (permalink)
I have seen a camshaft rusted to pieces on these engines and it made the same sound. Open the top of the engine and inspect the camshaft.
E420 '93
240D '83 "The wheel"
Contra verbosus noli contendere verbis, sermo datur cunctis, animi sapientia paucis.
daddi is offline   Reply With Quote
Old 07-18-2009, 02:10 PM   #9 (permalink)
i will check this... Thanks
Old 07-31-2009, 02:46 PM   #10 (permalink)
Hi
Today i kill the Engine the chain snap ( break) end of story of A140 ENGINE R.I.P ;(
Engine noise sgaar R/C107 SL/SLC Class 2 01-31-2009 07:55 PM
Road Noise/Engine Noise..PROBLEM FOUND Satch0922 W210 E-Class 9 08-08-2008 04:24 PM
Engine Noise Andreholl W211 E-Class 4 03-11-2008 07:28 PM
Engine Noise asad1 GL Class 2 10-26-2007 04:37 AM
engine noise Tan W163 M-Class 3 12-18-2001 01:00 PM
