» Sponsors
» Sponsors
Old 06-01-2009, 08:05 AM   #1 (permalink)
Date registered: Jun 2009
A Class 140 (yr 2000) indicators and windows stopped working
Hi all, this is my first post.
My A Class developed a problem with its battery where it would not hold any charge. So I changed the battery a couple of days ago.
All was fine for a couple of days, but driving it this moring, the indicators (hazards too) did not work (didn't even flash when you remote-lock). Also my powered windows no longer working. Fuses are checked and all ok....
Before I take this into a garage, have any of you had a similar issue or any ideas of a quick potential fix !!
Many Thanks
RAWHEAD is offline   Reply With Quote
Old 06-07-2009, 09:17 AM   #2 (permalink)
hi i have a c200 and once i had the same problem, the problem was the sam module when the batery is discharge or change the module don't work idon't know if you can program the module like the c200, well idon't know if your car have sam module.
follow the steps
unplug the batery and wait around 10 minutes
conect the batery and when the rpm are regular turn your steering wheel (slow) all to the left and all to the right return to the original position and try open a window or swich on the hazards
if you can't you need a dealer who program your car or search another way for manual programing
check te fuses!!!
grillo is offline   Reply With Quote
Old 06-23-2009, 01:46 PM   #3 (permalink)
Date registered: Apr 2009
Vehicle: 1989 300SE
Hello,
My father in laws A140 developed exactly the same problem. Now the electric windows only open about 3mm when the switch is pressed. So you can imagine how many times it needs pressing to open slightly.
Does anyone know how to rectifiy this?
Duggy72 is offline   Reply With Quote
Old 06-24-2009, 09:35 AM   #4 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
close each window, which as you say can take a long time, When fully closed press each switch appropriate to the window down fully and hold it down until you hear a click or 30 secs this action should re-set the windows follow the same procedure for easch window using the switches between the front seats
All this information is on my site along with masses of other info, Now if your really serious about wanting to service and understand your 'A' class purchase my CD . It will cost the price of one Bosch Spark plug purchased from Mmercedes parts and will save you a fortune. just the discounts available on my site will save you in some cases hundreds of ££££££££
Albert Rowe, Lofty's homepage
lofty is offline   Reply With Quote
Old 06-24-2009, 02:33 PM   #5 (permalink)
Vehicle: 1989 300SE
Hi Lofty,
The advice is much appreciated.
Will vist your website.
Cheers
Old 07-19-2009, 02:04 AM   #6 (permalink)
lofty's Avatar
thanks for showing your appreciation for the info, but di it help???
Old 07-19-2009, 01:40 PM   #7 (permalink)
Vehicle: 1989 300SE
yes, worked perfectly.
Old 07-20-2009, 05:22 AM   #8 (permalink)
lofty's Avatar
Great news,
masses of other info on my site Http://www.aclassinfo.co.uk/mypage.1.htm
HELP! Front windows stopped working! stevo99 W202 C-Class 8 04-04-2007 02:12 PM
All windows stopped working! scotta W140 S-Class 23 03-23-2007 10:40 AM
Both power windows stopped working today theratpatrol General Mercedes-Benz 2 07-23-2005 01:31 PM
Windows stopped working. Help needed. azatrum W201 190 Class 10 06-04-2004 07:04 PM
Windows, Brake Lights, etc., have stopped working: please help. Gallarda W123 E,CE,D,CD,TD,TE Class 3 05-22-2003 11:45 PM
