» Sponsors
» Sponsors
Old 04-24-2009, 09:08 AM   #1 (permalink)
Date registered: Apr 2009
Engine Management Query
Hi All,
My engine management lamp came on today. I am thinking about going and getting the code read but I thought I would ask a quick question first.
I ran the petrol tank almost to the minimum (we are talking down to fumes, though it never got empty) the day before the engine light came on. Could the two be related? Should I give it a good drive over the next few days before I take it in to see if it goes off?
Any comments will be greatfully received.
REMDUDE
remdude is offline   Reply With Quote
Old 04-25-2009, 05:13 AM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
I doubt if it will go off on it's own, I suspect you dragged some muck from the tank which possibley affected the flow of fuel, has your fuel filter been changed is it due for chang? The ecu lamp will light when the mixture is incorrect, I suspect the running very low on fuel is what caused your problem
You should be able to clear the lamp with a hand held diagnostics tool as is shown on my site, the initial cost would be slightly higher than going to MB to have the light deleted, and all they will have done is deleted a light, purchase the unit and you have it for all time, but your car does need to be petrol 2000 onwards diesel 2004 to ensure these units will work, i.e EOBD complient if you do decide to purchase follw the information on the page to get the discount offered. Either way if the cars running ok then there is no panic to do either
and it goes woithout saying that feed back would be appreciated what ever you decide to do.
Bert Rowe's-mercedes-benz 'A'-class info. (OBD2)(EOBD) On board Diagnostics scanners meeting OBD2 standard & A class Mercedes.
lofty is offline   Reply With Quote
Engine Management Light DaveyB W168 A-Class 4 03-04-2009 08:23 AM
Engine Management stallion8797 R170 SLK Class 5 12-06-2007 02:17 PM
Engine Management Warning ggevans R171 SLK Class 5 09-21-2007 10:23 AM
Q on ME 2.8 engine management. ushafiq W163 M-Class 0 02-28-2003 01:06 PM
Engine Management Computer Duncan R170 SLK Class 17 10-26-2001 06:41 AM
