» Sponsors
» Sponsors
Old 03-21-2009, 03:44 AM   #1 (permalink)
Date registered: Mar 2009
gearbox flush?
Hi all
I bought a mercedes a170cdi (t reg) 2 days ago with the F fault on the dash. The previous owner has always had it serviced by a MB Specialist.. The problem im having is when putting the car into reverse, there is a loud clunking about every 3 seconds, reverse works but there is some underlying problem. One of the things i noticed was that the winter summer switch was broke, i have removed the switch cover so i can see the board, but what i want to know is, could it be possible that its stuck in winter mode, this would explain why it starts of from second? Also the car is constantly in limp mode. I had the aa come out and take a look at it and it read error p1470 turbo boost pressue to high/low?
The aa man thought it could be something as simple as low gearbox oil.
Also the lady who i bought the car off said the MB specialist said it needs a gearbox flush as something is sticking? does this sound right? And roughly how much would it cost to get this flushed?
Also what gearbox oil is used in my car?
Sorry for babbling. Hope ive covered everything.
Thanks in advance for any light you can shed on this.
Tony
Xenoletony is offline   Reply With Quote
Old 03-22-2009, 07:35 AM   #2 (permalink)
Anyone?
Also has anyone got a part number for the auto gearbox oil dip stick?
Helloooooooooooooooo
Old 03-22-2009, 09:40 AM   #3 (permalink)
Hi again
Upon further inspection under my bonnet, i found a connector that wasnt plugged in? i found that it plugged into the top front left of the engine. i have a pic that i will upload later, could this of been causing the F fault and would i need to clear the code in order to get out of limp mode or will it clear on its own? If i need to clear it can i do this by disconnecting the battery? or some other trick?
Why would this be disconected, please take a look at the 2 images, thanks,
a. was 2 loose cables( the problem im having was low boost pressure.)
b. dunno what this is, just a landmark, maybe you can see what it is on your car, the lead plugs in just next to this.
plugged the cable back in but fault is still on, possibility it needs clearing? any help would really be appreciated.
Thanks tony
Anyone use the 'Prestone Flush and Fill Kit' when doing a flush? benztech123 W123 E,CE,D,CD,TD,TE Class 2 11-16-2008 06:16 PM
To flush or not to flush? Newspug General Mercedes-Benz 22 10-30-2008 11:16 AM
Colant flush....how often? JAD W163 M-Class 5 06-13-2007 07:05 PM
transfer gearbox /gearbox parts for 463 G-wagen redao G-Class 1 03-30-2007 10:42 AM
transmission flush jtbeche W208 CLK Class 6 01-21-2006 05:21 PM
