» Sponsors
» Sponsors
Old 03-07-2009, 01:27 PM   #1 (permalink)
Date registered: Mar 2009
Question A140 one piston not firing
Hi,
I just bought an A140 S reg (1999), and I've got couple of problems with it.
The engine sounds like running on 3 pistons only (sounds like a diesel engine). First, I changed all the filters, oil and spark plugs, no change. I took it to garage, they hook it up to the computer and gave a faulty air mass sensor (it shows low voltage). The guy who did the test said that in his opinion it's not the sensor but a weak contact or damaged wire.
Today I took out the spark plugs(which were fitted 3 days ago), and one od them it looks brand new (like it never fired), rest of them are slightly black (burned), so I guess one piston is not firing.
Could be a connection between air mass sensor and ignition module??
If anyone had this problem before, or knows what it might be, please advice.
Thank you
Paul
maximallimit is offline   Reply With Quote
Old 03-08-2009, 06:07 AM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
I would have thought it was more likely to be the connection between the ignition module and the offending plug, it's not the coils because each of them serves two plugs,
I feel sure you can get the bits that go to make up the contact see if you can get hold of a module to confirm the problem, the diagnostics should have pointed out the plug that's not firing if that is the case .
feed back would be appreciated
lofty is offline   Reply With Quote
Old 03-08-2009, 07:40 AM   #3 (permalink)
Thanks Lofty. I read all your website, it's great mate...keep up the good work.
anyway....I checked and cleaned all 4 connections (springs) between ignition module and spark plugs at no avail. Is there a way to open up the ignition module, to check for broken connections or something?
Old 03-08-2009, 02:08 PM   #4 (permalink)
lofty's Avatar
Afraid not, open you wallet yes! £85 ish or e-bay loads of A's being broken you could well pick up a good one there .
Problem with a140!! lazaross W168 A-Class 6 07-01-2008 06:18 AM
Mercedes w123 240D cracked piston. What caused the piston to crack? teodor W123 E,CE,D,CD,TD,TE Class 6 07-30-2007 01:52 AM
A140, a good choice? levin W168 A-Class 2 01-18-2005 09:54 AM
Firing order and piston # 1 ???? Please Help glunatec W201 190 Class 9 10-04-2004 08:52 PM
A140 problems when idle... Joran W168 A-Class 1 05-13-2004 12:46 AM
