» Sponsors
» Sponsors
Old 02-21-2009, 01:48 PM   #1 (permalink)
Date registered: Sep 2008
Vehicle: v220cdi A140
Indicator, wiper, washer problem
Hi, we recently brought a A140 (2001 great little car), noticed the windscreen washer didn't work, so I checked it out, no power, back to fuse opps it was missing.
Great new fuse and now it works-- but when I put the indicators on the windscreen wipers also come on, has anyone had this problem before and what is causing it?
littlerattled is offline   Reply With Quote
Old 02-27-2009, 12:37 PM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
What you will find ids that there is a fault inthe combination switch, Ican be replaced cost about £85-£100 some times available on e-bay s/H but the amount of work to replce makes sense to replace with new.
The other common fault is you can't dip main beam.all caused by the dicki switch.
at least you now know why the previous owner took it out.
But remember the washers must work if fitted for the car to pass the MOT
lofty is offline   Reply With Quote
Wiper Washer Leak SteveMras R170 SLK Class 1 01-26-2009 08:52 PM
Windshield Washer Indicator Problem - HELP! vip W163 M-Class 5 02-11-2008 08:08 PM
washer wiper cashman W123 E,CE,D,CD,TD,TE Class 6 02-16-2007 05:48 PM
Rear wiper and washer wilvanderk W124 E,CE,D,TD Class 1 06-09-2005 12:49 PM
Rear Wiper/Washer tobert W163 M-Class 3 12-06-2002 07:40 AM
