» Sponsors
» Sponsors
Old 01-29-2009, 12:06 PM   #1 (permalink)
Date registered: Jan 2009
Vehicle: R320 CDI
A class, ABS fault
Hi guys and girls.
Coming to you from across the pond, need some help finding a fault on a mates a,class.
ESP/ABS on dash, short test results showing-
Solenoid valve FR
Increase pressure.
None of our UK guys have seen nor heard of this one before!
Wiring checks out, ABS pump been replaced,
Im thinking ESP control module now!
You guys ever seen or heard of this one before??
coleman GB is offline   Reply With Quote
Old 01-29-2009, 09:13 PM   #2 (permalink)
Date registered: Mar 2007
You have tons of reading to do... info abound here on the site... my car says check the battery and start-up voltage first. Indicator lights up at low voltage. Might be different for your car - maybe an expert will chime in.
You may want to provide more info about the problem, when or how or what happened to cause...etc.
Dave
DAVerchick is offline   Reply With Quote
slk 230k 99 model abs asr fault+ transmission fault evopg R170 SLK Class 13 05-17-2009 08:23 PM
ASR/ABS FAULT mercS600 W140 S-Class 11 04-16-2009 04:11 AM
Directional Tyres/ABS Fault??? Dolphin27 R170 SLK Class 4 05-15-2006 07:09 AM
ABS/ETS fault codes W210 A1EK W210 E-Class 3 11-02-2005 07:29 AM
help needed with abs fault ramses W124 E,CE,D,TD Class 5 06-23-2005 08:23 AM
