» Sponsors
» Sponsors
Old 01-28-2009, 10:36 AM   #1 (permalink)
FAILACE's Avatar
Date registered: Jan 2009
Vehicle: A160
Send a message via MSN to FAILACE
AUTOMATIC TRANSMISSION DOES NOT SHIFT
Hello.
My transmission does not shift to upper gears. Ex: 60Km/h = 3rd gear. I can ride to the moon in third. Riding along with other A190 auto, my car is always one gear down. She has 52000Km, new trans oil and filter, StarDiagnosed OK. Please, HELP!
FAILACE is offline   Reply With Quote
Old 02-18-2009, 04:45 PM   #2 (permalink)
Date registered: Feb 2009
Vehicle: 1999 A160 Avant Garde
Originally Posted by FAILACE View Post
Hello.
No answer but yeah I have same problem with my A160. Goes anywhere in 3rd but wont shift any higher. Also F on dash. One garage reckon the clutch drum's split and that it will cost me at least £1500 to sort out. Help!! Is there any other alternative??
Kudakwashe is offline   Reply With Quote
Old 02-18-2009, 05:09 PM   #3 (permalink)
Hello.
Oh and my error code is P1889 if anyone knows what it means. I really dont want to sheel out £1500 if I can help it
Old 02-24-2009, 10:42 AM   #4 (permalink)
NEOKEN's Avatar
Date registered: Dec 2007
Vehicle: 1995 SL500 - K&N Filters, Modified Intake, Modified ECU, Ported & Polished TB, HID Xenon Conversion
Hi Ricardo and welcome to Benzworld.
Is your transmissoin service up-to-date including fluid replacement, gasket filter, etc?
Have you checked that the ATF is at correct level?
Best Regards.
Ken
NEOKEN is offline   Reply With Quote
Old 02-24-2009, 10:45 AM   #5 (permalink)
NEOKEN's Avatar
Error code P1889 - 2-5-R downshift PWM valve pressure too low transmission slipping.
Old 08-01-2009, 06:20 PM   #6 (permalink)
Date registered: Jul 2009
Vehicle: A160 Auto, Toyota Supra
Did you manage to fix the car? If so, what did you have to do to fix it and at what cost?
ihshaikh is offline   Reply With Quote
ATF - automatic transmission fluid - 722.6 five speed automatic masaki@japan R129 SL Class 48 06-12-2009 03:40 PM
When I start the car, the automatic transmission doesn't shift rsteckly W201 190 Class 6 01-15-2009 07:26 AM
how do you reset the automatic transmission shift memory blkbenzz General Mercedes-Benz 16 06-19-2006 03:16 PM
Automatic transmission question: anyone knows how to make the transmission shift at a higher RPM, DanPro1 R170 SLK Class 8 10-07-2002 03:35 PM
Prefacelift SLK: shift-knobs for automatic transmission can be installed on manual transmission? Marcello (Piacenza - R170 SLK Class 3 04-26-2002 12:05 PM
