» Sponsors
» Sponsors
Old 01-13-2009, 02:54 PM   #1 (permalink)
Date registered: Jan 2009
A140 Loss of power at low revs when accelerating
Dear all,
Newbies to the Benzworld! Apologies if this topic is covered elsewhere.
A friend of mine has got a A140 Classic (2000). She is having problem when accelerating. Basically the car is lack of pull at low rev <2,500rpm. It seems that the rev will stick at around 2,000rpm for 1-2 seconds before it can seriously pulls off.
When idle, neutral gear, flooring the accelerator, again the engine is "stuck" for 1-2 seconds before it revs up.
Can someone give me some hints of what is the problem likely to be?
Many thanks!
kevkmkwok is offline   Reply With Quote
Old 01-14-2009, 01:14 PM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
Could be the accelerator pedal sensor.
You will appreciate their is not physical connection cable etc so you are reliant on the sensors.
However it could be connected with fuel flow, has the fuel filter been replaced at the prescribed periods also the air filter all have a part to play and need to be clean condition.
http://www.aclassinfo.co.uk/mypage.12.htm
& page 16
lofty is offline   Reply With Quote
Loss of engine power and shushing on accelerating Jon Proffitt W163 M-Class 2 10-12-2008 02:35 AM
CEL,Rough Idle, Low RPM Power Loss pmwestx R170 SLK Class 15 09-16-2008 11:50 AM
1988 2.6 automatic, No power on low revs and big fuel consumption delete W201 190 Class 2 10-04-2007 05:05 AM
Jerky at low revs - is he right? Playtime R/C107 SL/SLC Class 16 12-04-2006 01:55 AM
Sluggish and power lag when accelerating at low-mid range... louistrd W124 E,CE,D,TD Class 4 02-09-2005 10:07 AM
