» Sponsors
» Sponsors
Old 12-04-2008, 09:08 AM   #1 (permalink)
tobyd's Avatar
Date registered: Sep 2004
Vehicle: e280t
A170 drive shaft broken - big job?
Hi,
I've just had a call to say that the drive shaft on my sisters 2002 A170 has broken and was wondering whether this was a common thing and if its a big job to do?
Any help would be appreciated.
Thanks
94 E280T
tobyd is offline   Reply With Quote
Old 12-04-2008, 01:23 PM   #2 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
The first one I have heard of in nearly 6 years
You'll have to remove all the hub components but replacing the shaft should be that large a job, mercedes of course will say it's a big job and will have to put it on the diagnostics to tell you what's wrong with the car just to back up the bill !
Now if your in the UK you should be able to get hold of a good unit off e-bay plenty of 'A' s being broken at present. make sure you get the right one because one side is split into two shafts
lofty is offline   Reply With Quote
help broken drive shaft mrwow42 General Mercedes-Benz 2 06-15-2008 07:55 AM
help broken drive shaft mrwow42 W123 E,CE,D,CD,TD,TE Class 0 06-14-2008 05:59 AM
Broken cam shaft Open top 380 R/C107 SL/SLC Class 3 03-23-2007 04:27 PM
Old car + metal fatigue = broken half-shaft matsalleh76 W201 190 Class 0 05-17-2006 11:12 AM
drive shaft broken Rocha G-Class 16 09-30-2005 08:21 AM
