» Sponsors
» Sponsors
Old 10-06-2008, 06:06 AM   #1 (permalink)
Date registered: Jul 2008
A170CDI auto stuck in neutral
Hi everyone -
I've got the (common?) problem with my auto-box on my A-Class where I've been driving about, parked up, gone to put the car back up into 'Park' only to find that the gate on Reverse is locked, leaving not only the selector lever in Neutral or Drive, but not allowing me to remove the keys from the ignition either.
I've had this on and off for a while with the box always going back to normal after 5 minutes or so and I have already replaced the switch by the brake pedal but now the car seems resolute about not going back through Reverse.
Does anyone have either A) any suggest on what I should try next to sort this and B) any idea of a manual override on the A-Class?
I'd be really grateful for all suggestions.
Thanks,
DT.
discotroll is offline   Reply With Quote
Old 05-09-2009, 12:11 PM   #2 (permalink)
Date registered: Apr 2009
Did you ever figure this out? I'm having the exact same issue with a 2002 C230.... i'm about to check fuses but I'm fearing I will have to take it in, and get it towed.... or I could drive it as long as I don't have to go in reverse!!! Lame.
Originally Posted by discotroll View Post
Hi everyone -
Thanks,
DT.
Mook2420 is offline   Reply With Quote
stuck in 3rd/auto transmission fat170 New Member Introductions 1 08-31-2009 10:38 AM
Gear Selector Stuck W202 Auto hogbacon W202 C-Class 8 07-27-2008 12:44 PM
Gear Selector Stuck W202 Auto hogbacon General Mercedes-Benz 0 07-26-2008 03:54 AM
SLK auto transmission stuck in first Chris Walker R170 SLK Class 11 08-14-2002 09:11 PM
W124 230E Auto Transmission won't ignite at Neutral Guest (MBNZ) W124 E,CE,D,TD Class 2 02-06-2002 12:19 PM
