» Sponsors
» Sponsors
Old 09-24-2008, 02:46 AM   #1 (permalink)
emman's Avatar
Date registered: Sep 2002
Vehicle: 93 190e /2001 220CDI
Unhappy Fan belt
Hi Guys,
My wife drives a 2002 160 CDI A Class and for some reason her fan belt has broken three times in the last year. We have had the alternator checked, changed all the rollers and tensioner but the belt just got damaged again. Any thoughts or experiences out there?
bull
emman is offline   Reply With Quote
Old 10-15-2008, 02:32 AM   #2 (permalink)
Date registered: Jun 2008
Hi, did you check the alignment of all the rollers, tensioners and wheels?? And check the broken beld... can give you an ideea about the problem...
Good luck!
RazvanC is offline   Reply With Quote
Old 12-13-2008, 07:24 AM   #3 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
Well it's not a fan belt but I know what you mean it's the poly V belt runs water pump air con alternater etc.
One problem that can cause this multiple belt fraying and breakage is where the main drive pulley wheel shed the outer vulcanised rubber casing.
best seen on my my site
Bert Rowe's-A-class info. Poly 'V' Belt, Crankshaft pulley wheel problems.
And it's not easily spotted so take a look.
lofty is offline   Reply With Quote
Old 12-26-2008, 10:54 AM   #4 (permalink)
emman's Avatar
Thumbs up
Great stuff Lofty, will be inspecting the complete adjuster unit after the holidays. Currently the vehicle is parked since we broke two more belts since my last posting. Will keep you posted.
Old 12-29-2008, 03:51 AM   #5 (permalink)
lofty's Avatar
If you are fitting these belts yourself make sure they follow the correct path, it's not straight forward when you get under the car and remove the old belt. follow the wrong path the belt will shread. 2 belts, 1 for air con 1 for non aircon both are different layouts.
Old 01-02-2009, 07:25 AM   #6 (permalink)
emman's Avatar
Thumbs up
Lofty it all worked out well and my wife is back on the road. Thanks for your valuable input.
Old 01-03-2009, 04:21 AM   #7 (permalink)
lofty's Avatar
Question So how did you solve the problem?
Glad it worked out well but what worked out ?
It would be helpful if you could indicate how /if you solved the problem!
I suspect the belts were incorrecly fitted, but that only a guess?
We do all make mistakes you know, and the guy who says he doesn't make mistakes never made anything!
fan belt (V-belt) life? benzwag W126 S,SE,SEC,SEL,SD,SDL Class 7 02-01-2008 07:18 AM
Fan Belt wvh187 W201 190 Class 3 08-02-2007 10:39 AM
Fan Belt Tensioner The Melmaan W201 190 Class 5 12-01-2006 06:36 PM
Fan Belt Braingears G-Class 2 04-10-2006 09:39 AM
Help with Fan Belt Brian Felts W124 E,CE,D,TD Class 1 10-23-2005 09:44 AM
