» Sponsors
» Sponsors
Old 09-04-2008, 11:43 AM   #1 (permalink)
Date registered: Aug 2008
A160 H1 WARNING
After running the engine for 10 minutes, a H1 warning is displayed in the instrument cluster, anyone have any ideas on what that could mean? This occurs on each journey
fortec is offline   Reply With Quote
Old 09-05-2008, 05:37 PM   #2 (permalink)
Date registered: Sep 2008
Hi Fortec,
I have this problem from time to time too, esp after a service. It just means that the oil level is high and you need to drain some oil from the sump.
There is more information on this post from a member experiencing the same issue:
http://www.benzworld.org/forums/w168...ps-coming.html
Hope that helps,
Mo
Moski is offline   Reply With Quote
Old 12-01-2008, 04:38 AM   #3 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
Spot On, despite some owners think the car was just being sociable when they first turn the key it does inform you that the oil is too high.
Draining a small amount out is important as the HI oil level can damage the cat. See the note on the oil filler it could be clearer.
If MB are responsible then take the car back and get them to remove the surplus oil it might make them take more care in the future
lofty is offline   Reply With Quote
Batterychange a160 DaSonic Audio & Telematics Forum 1 07-31-2008 06:07 PM
A160 Pickup - Is it just me...? flair77 W168 A-Class 6 03-31-2008 01:00 PM
A160 help laksa W168 A-Class 2 07-27-2007 03:03 AM
F1 v A160 v E50 conleycrew3 General Mercedes-Benz 10 12-31-2005 07:16 AM
A160 AV With ECU... Shermio W168 A-Class 2 09-09-2004 05:03 PM
