Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Old 06-19-2008, 02:19 PM   #1 (permalink)
Date registered: Jun 2008
Gear box & Clutch problem
I have a 1999 A170 CDI Avant Guarde S-A. I have just had the clutch (Clutchless manual operation) and gearbox replaced due to a bearing collapse in the gearbox. Approximately 1000 miles following the repair, noise from the gearbox increasingly worsened. At this time, I returned the car to the garage. They stripped the gearbox down and found worn “dif” gears. Per the garage, they had never seen so much wear for such few miles driven. Repairs were made at this time. After driving approximately 30 miles from collecting the car for the second time, I began to hear a slight whine coming from the gearbox. Notified the garage and the car was returned once again. By this time the clutch began disengaging while I was driving. The car was left again at the garage for repair. While the garage was test driving the car, it broke down and had to be towed to the garage. The current status, per the garage, is the diagnostics are normal and the problem is not with the gearbox and/or clutch, they do not know what the problem is. Can anyone please help regarding this matter?
emorshuis is offline   Reply With Quote
Old 07-01-2008, 07:43 PM   #2 (permalink)
Vehicle: Merc A160 & Honda civic
Are you still experiencing the same problem. It sounds as if they are giving you a bit of a run around.Are there any fault codes.
reaperron is offline   Reply With Quote
Old 07-15-2008, 05:41 AM   #3 (permalink)
Date registered: Apr 2008
Hello
Maybe if in the garage they only replace the clutch you have always that problem in the future. They have to change apart from the clutch the flywheel.
Hope helped.
Regards.
jrfsantos is offline   Reply With Quote
Big problem with automatic gear box ?. Lack of power. piapia General Mercedes-Benz 0 04-18-2008 10:44 AM
Gear box problem? saj8162 R170 SLK Class 1 03-15-2008 05:53 AM
AUTO GEAR BOX ( CLUTCH ) TOMMYMCA79 V-Class 4 01-06-2006 03:58 PM
A170cdi automatic gear box problem Guest (MBNZ) W168 A-Class 5 10-07-2005 04:43 AM
Please help...Gear Box Problem Nawaid W201 190E, D-Class 5 12-01-2003 05:12 AM
