Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Old 04-14-2008, 03:31 PM   #1 (permalink)
Date registered: Apr 2008
centre dash removal
hi there i want to replace the single din stereo i have in my 2001 A-class W-168 with a new double din unit i have. can anyone tell me where i can get details on how to remove the centre console so that i can install the new 2 din mounting ?
Deanofire is offline   Reply With Quote
Old 05-15-2008, 02:19 PM   #2 (permalink)
Date registered: May 2008
hi there,
first of all you need to remove the din size radio,
then you if you have a pocket or cd storage underneath you will have to take that out, to do this,m when you take the radio out you will see at the bottom, at the back to plastic lugs holding the frame in, push these down, and pull at the black plastic frame.
once you have done this you will relise that there is a double din space, but there is a plastic running across the middle, you then need to cut this out from either size using a hack saw. when cutting this remember to leave a least 2-3 mm each size then start cutting, this is so that the cage of your new unit fits ok. you then need to cut the back bottom plastic strip as well.
you now have the space for the double din.
as they do not make a facia for the a class. you have to put the original plastic that you took out. if you cut out the gap where the pocket or cd storage out and the bottom plastic trim. it will ten be finished of nicely.
be aware, if you do like cutting things do not do it take it to a professional, not to halfords.
ive do it on my car and it looks great, but be warned, you need to be carful and have patients.
J111NNT is offline   Reply With Quote
Dash removal help worksux W163 M-Class 1 09-16-2007 06:52 PM
Dash Centre Panel psmith V-Class 2 02-18-2007 11:20 AM
Dash and centre console lighting? W140 S class titanium1 W140 S-Class 4 12-25-2005 06:40 PM
Dash and centre console lighting? W140 S class titanium1 General Mercedes-Benz 1 12-19-2005 02:05 PM
Replacing one dash trim piece takes removal of whole dash and full day!!! Dan R170 SLK Class 4 09-04-2001 04:25 PM
