Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Old 04-12-2008, 02:22 PM   #1 (permalink)
Date registered: Apr 2008
Reolacing A140 Front lower suspension bolts
I intend to carry out some work on my friends W reg A140, which will neccesitate according to him (he is over 65 -we live over 60 miles apart) removing the front wheel/brake assembly holding bolts. (2 off) (suspension spring replacement being undertaken.)
Do MB recommend officially recommend replacing these bolts, or can they be used again?
He is unsure how they hold on - nyloc, blue locktite or other means - and I want to ensure that I have the right equipment here when he comes over to stay for his 3 days holiday.
I was always taught to replace nyloc nuts (if fitted) in all cases and in some cases to use catelled nuts with pins as an alternative.
I would prefer to know:
a) the offical line and
b) DIY mechanics views if different.
Thanking you for your help and I apologise if posted in the wring section as I am a first time user here
peterfisherman is offline   Reply With Quote
To lower, or not to lower my '07 E550 with airmatic suspension >>> geo0602 W211 E-Class 4 03-02-2008 01:38 PM
changed rear suspension busing.. !@#$% seized bolts!!!! *pics* snik W140 S-Class 3 01-11-2008 11:00 PM
how can i lower a '04 w211 with airmatic suspension? MIHAI320 The Discount Tire Direct Tire, Wheel, Brake & Suspension 3 12-07-2006 10:03 PM
Suspension: To lower or not to lower Big D W126 S,SE,SEC,SEL,SD,SDL Class 2 03-23-2004 09:35 AM
dont lower your slk without having camber bolts installed ashroxamg R170 SLK Class 6 09-14-2001 06:01 AM
