Hi all, car now takes 3 attempts to start from cold,when it does start it idles roughly,and when you try to accelorate it coughs and splutters.When it warms up,it runs ok.If you take it for a run then turn it off,and try starting it again the problem arises.Have taken off the mafs meter and cleaned it,the two glass reeds are not burnt or broken,it seems to be in good order.
sent ecu to injection correction/bluestreak ltd. they tested it,and found it to faulty,cost of repair £168 plus £8 delivery.well pleased with service,next day.
