air flow problem - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-24-2007, 06:51 AM Thread Starter
Date registered: Aug 2007
Unhappy air flow problem
can someone please help. I have a 1998 A140 semi auto it has been diagnosed as having a faulty air flow sensor i have been told as it is semi auto the air flow sensor can not be changed and i need to buy a complete ecu is this right?As there is nothing wrong with the ecu is there anything i can do?
danb9990 is offline
post #2 of 5 (permalink) Old 08-24-2007, 01:17 PM
Date registered: Jul 2007
Hi there
Unfortunately the mass air flow sensor and engine control module are integrated - so you have to replace both if one fails. There is a picture on Loftys page here:
Bert Rowe's-A-class information.mypage.38.htm
It does look like you can buy a reconditioned unit from BBA-reman.com who will just post out a reconditioned unit to you as long as you then send the old one back - but I'm not sure if they do the programming of the ECM to match your car (which Merc say is necesary).
Kiwi A160 is offline
post #3 of 5 (permalink) Old 08-25-2007, 11:08 AM Thread Starter
Smile
thanks guys ill check loftys web page and inquire with bba reman
danb9990 is offline
post #4 of 5 (permalink) Old 08-26-2007, 07:09 AM
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
Have just responded on the duplicate question.
BBA ReMan do not sent out recon units they repair your cars unit and return it ECU/MAFS as with remote key fobs (sold on e-bay and elseware)taken from other cars 'A' Class, will not work with your car they are coded .
please see all the info on my site page 6 & 38 Albert Rowe, Lofty's homepage.index.html
lofty is offline
post #5 of 5 (permalink) Old 08-26-2007, 10:54 AM
Thanks for clarifying that Lofty - when you click through their web page "Mercedes" "Airflow Meter" "A Class" you are told this:
We send you out a working unit and you send your old unit back after you fit this one. If for any reason we do not receive your old unit back, there would be an additional charge of $150
Searching via the Common Problems link, I found the right page:
Mercedes A Class Air Mass Meter and ECU
Cheers
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Oh boy, Air flow problem (A/C,heat) ghost W140 S-Class 11 10-02-2009 03:05 PM
Heating air flow vs. AC air flow okiloveu W210 E-Class 5 11-10-2006 10:42 PM
air flow plate (fuel distribution) problem mercedes84black W126 S,SE,SEC,SEL,SD,SDL Class 3 01-26-2006 07:56 AM
air flow plate (fuel distribution) problem mercedes84black W126 S,SE,SEC,SEL,SD,SDL Class 0 01-25-2006 02:13 PM
AC Problem - Low Flow in Center Vents / Minimal Flow in Rear rrgua W210 E-Class 5 08-11-2005 04:40 PM
