» Sponsors
» Sponsors
Old 02-06-2007, 05:45 AM   #1 (permalink)
Date registered: Feb 2007
Starter or ignition?
Hi everybody,
I have problem with my starter (car 2000 A140). When you switch the key, starter doesn't start at all, no sound. Its enought to switch ignition back and switch it again: engine starts in one or two starter spins. And this problem appeared only when the outside temp. droped below -10Co. Now is about -2Co, but the problem still occurs. I think the problem can be with ingition lock or wiring from ignition to starter (cold, wet :-? broken wire).
Can somebody give advice what should I do, how to check starter if it is not broken?Thank you
mcdee is offline   Reply With Quote
Old 02-17-2007, 08:57 PM   #2 (permalink)
Vehicle: 2001 A160
Hi McDee,
Generally speaking if the starter is faulty then it will always be faulty. When you turn the key to start and nothing happens with the starter do the dash lights dim? I strongly suspect you have a starter relay fault but explain a bit more what happens to the interior lights when the car fails to start.
Check your battery terminals and then get your starter relay checked I would say.
Hope it helps.
malice is offline   Reply With Quote
Starter, Solenoid, or Ignition Switch jkkasl R129 SL Class 2 02-06-2007 02:51 PM
starter Jippi W201 190 Class 0 09-14-2006 08:23 AM
Non-starter ! deathrattle Off-Topic 6 06-21-2005 04:01 AM
STARTER/IGNITION/?/PUZZLED DOUGLAS MARTIN W123 E,CE,D,CD,TD,TE Class 4 07-19-2004 10:25 AM
starter bloodpirate W124 E,CE,D,TD Class 3 02-10-2004 10:44 AM
