» Sponsors
» Sponsors
Old 12-19-2006, 04:52 AM   #1 (permalink)
Date registered: Dec 2006
SRS Problem
I wonder if anyone can help.
I have an A140 (52) Elegance model and it has a problem with the airbag SRS warning light.
Basically there is a sensor in the passenger seat which is not working correctly, in that when there is no one seating in the seat the SRS light warning light is illuminated on the dashboard.
When the passenger seat is occupied then the light goes out.
I have taken it to my local Mercedes dealer and they have confirmed that there is a switch is the seat which detects if there is a Mercedes baby seat present and disables the airbag accordingly. According to Mercades this switch is not working correctly and it will cost over £500.00 to replace.
I think this is unacceptable and are therefore looking for help and guidance on how to undertake the work myself.
Has anyone attempted this or have any ideas where to start.
Any help much appreciated
Regards
James Mackay
jimmy.mackay is offline   Reply With Quote
Old 12-23-2006, 09:10 AM   #2 (permalink)
wont be to hard but you may have to pay to get the fault cleared
you can remove the seat base without removing the full seat its under the seat cover
mercuk20 is offline   Reply With Quote
Old 12-23-2006, 10:38 AM   #3 (permalink)
Thanks, I wil give it a go.
Do you know of any diagrams available showing how to undertake the operation?
Old 12-27-2006, 09:08 AM   #4 (permalink)
sorry mate sent you the wrong message the seat cover is held on by plastic clips which fold onto the seat from below remove them and the cushion will lift up
are you in the uk as they may be different elsewhere
SRS Passenger Seat problem Guest (MBNZ) W210 E-Class 14 06-03-2009 09:05 PM
$1100.00 SRS Problem pulm W163 M-Class 12 07-28-2006 06:00 PM
SRS Light and another problem 4be W124 E,CE,D,TD Class 2 04-03-2006 01:54 AM
SRS problem solved. jojo W163 M-Class 1 06-04-2003 09:30 AM
SRS Light on, 1st ML problem Dave L. W163 M-Class 7 11-13-2001 06:25 PM
