Hi, I have an A170 with the EPC Light on, Fuel is restricted now and can be difficult to start.
I have not yet had the car checked with an obd scanner - computer diagnostic machine. However, If you have had yours diagnosed to be the ECU and you have had that changed? then I would check your connections - plugs are all clean and a tight fit.
I was hoping to pick up some info before spending money on the diagnostics.
Good luck this time round.
