» Sponsors
» Sponsors
Old 08-29-2006, 12:31 AM   #1 (permalink)
Date registered: Feb 2005
Vehicle: A-Class (W169)
Send a message via ICQ to SirOracle
Climate control in the 2006 A-Class
Hi,
I have a question climate control in my A-Class (C169 latest one with standard climate control not THERMOTRONIC).
To which temperature does it compare your setting to decide will it blow warm or cold air? In the manual it said to the outside temperature, why is it so? WOuldn't it be more logical to compare it to the inside temperature? Because sometimes it happens outside is chilly (below the setting) but the car was on the sun so inside it is relatively hot, and still the climate control blows hot air (it was set to 22 degrees C). After I put the knob toa temp. below outside it started blowing cold air..
I don't quite get this why did they make it like this..
Thanx!
SirOracle is offline   Reply With Quote
Old 09-06-2008, 02:18 PM   #2 (permalink)
Date registered: Sep 2008
Vehicle: Mercedes-Benz A Class A150 2006, Volkswagen Golf 1.6 1999
im not sure but in the short hot spell the uk had, when having my air conditioning on the windscreen went frosty with the cold...it certainly works but I didn't know it decided on the air temperature i thought it was just from the setting one choses on the air con?
MBACE is offline   Reply With Quote
cruise control vs. climate control CCarlisle W123 E,CE,D,CD,TD,TE Class 0 11-04-2005 10:51 PM
climate control kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 0 10-17-2005 05:15 PM
Climate Control enigmamdw W126 S,SE,SEC,SEL,SD,SDL Class 5 09-28-2005 04:39 PM
CLIMATE CONTROL 300SEL4J W126 S,SE,SEC,SEL,SD,SDL Class 6 09-02-2005 03:45 PM
climate control Guest (MBNZ) W124 E,CE,D,TD Class 5 06-10-2002 04:07 PM
