» Sponsors
» Sponsors
Old 05-03-2006, 02:33 AM   #1 (permalink)
Date registered: Feb 2005
Vehicle: A-Class (W169)
Send a message via ICQ to SirOracle
Squiking noise in the engine (W169)
Hi,
I have an new model A-Class (W169) about 6 months old. I hear a squiking noise from the engine when it is cold. It dissappers after a while. The noise is not loud and it can be heard only from outside or with open windows. Is this a problem, should I do sometihing? or is it "work as designed" feature maybe..
Thanx!
SirOracle is offline   Reply With Quote
Old 05-05-2006, 05:04 PM   #2 (permalink)
RBs
Date registered: Apr 2006
Vehicle: 2001 S430
Air pump or perhaps the bearing between the belt spring tensioner and the pulley?
RBs is offline   Reply With Quote
Old 05-11-2006, 02:10 AM   #3 (permalink)
I don't know should I go to service since I am in warranty?
Old 05-16-2006, 02:58 AM   #4 (permalink)
Date registered: Sep 2005
Vehicle: A_Class W169 160_CDI
Probably a belt or pulley as previously suggested. Being ' In warranty' you should visit your dealer, as if it were to turn into something more serious they may say that you should have visited earlier and contest your claim. It is not a 'design feature' !
Do not let them charge you for a service, and regulary check you oil level using the dip-stick. Else the ASSYST may say you need a Service and they will charge you !.
Dave_160CDI is offline   Reply With Quote
