» Site Navigation
» Other Sites
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Old 08-06-2005, 07:03 AM   #1 (permalink)
Date registered: Aug 2005
A160 engine stall
I recently bought a 1998 A160 which has an engine stalling problem. When the car is driving, it has an initial problem accelerating then when it does accelerate if you stop, the engine will stop. The problem also seems to be worse when the air-conditioner is turned on. The diagnosis said it was a fuel filter problem, however, when the fuel filter was changed the problem still exists. Any advice?
Edin is offline   Reply With Quote
Old 08-07-2005, 02:31 PM   #2 (permalink)
Shermio's Avatar
Date registered: Jul 2004
Send a message via MSN to Shermio
RE: A160 engine stall
Could Be A Range Of Things From Blocked Fuel Line, Fuel Pump Problems, To Your Airfilter Being Blocked... It's Hard to Say, Is There A Lot Of Smoke Whne You Start The Car?
d(O_o)b
Shermio
http://perpetualdreamer.deviantart.com
1999 Mercedes A160 Avantgarde RS (SOLD)
1996 Mercedes E230 (First W210 E-Class In New Zealand)
2002 Mazda MX-5 SE (1 Of Only 15 In New Zealand)
Shermio is offline   Reply With Quote
