Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Old 08-02-2005, 03:43 AM   #1 (permalink)
Date registered: Aug 2005
Steering problem
My wifes A170 has developed a strange fault, when turning the car the wheel get's stuck and requires a little effort to get it unstuck whilst turning. It almost seems like the steering lock is catching, but strangly if I hold it in the stick position for a second it will turn fine. The problem does not happen if the car is stationary only when moving. The steering makes all sorts of creaks when turning. I have checked the powersteering fluid level and it is at the maximum.
Any idea what the problem could be ?
Thanks
Sully
hungabunga is offline   Reply With Quote
Old 08-03-2005, 04:19 PM   #2 (permalink)
Shermio's Avatar
Date registered: Jul 2004
Send a message via MSN to Shermio
RE: Steering problem
Wow That's A New One...
But I Would Try To Adjust The Steering Column First, Give It A Wiggle And See If Anything Is Stuck... It Could Also Be The Steering Arm, Did You Hit Anything Recently? It Could Have Bent The Arms Slightly Also Maybe A Small Stone Or What Not May Have Been Caught In The Steering Mechanism...
Hope This Helps...
d(O_o)b
Shermio
http://perpetualdreamer.deviantart.com
1999 Mercedes A160 Avantgarde RS (SOLD)
1996 Mercedes E230 (First W210 E-Class In New Zealand)
2002 Mazda MX-5 SE (1 Of Only 15 In New Zealand)
Shermio is offline   Reply With Quote
Old 09-14-2005, 11:32 AM   #3 (permalink)
Date registered: Sep 2005
Vehicle: 250 TDI (W202)
Seems you may have a common problem take a look at the BabyBenz site.
http://baby-benz.com/portal/content/view/224
There are a few cures apart from exspensive replacement, depending on mileage MB(?) may help. HTH [:(]
davesedgley@tiscali. is offline   Reply With Quote
Old 10-21-2005, 01:32 PM   #4 (permalink)
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
Although you have had no feed back at present this was a common fault caused by the bottom UJ seizure, can be easily overcome by spraying with copious spays of WD40 and exercising left to right, then lubricating by putting oil and grease mixture into the gaiter. In severe cases by replacing the lower UJ which can be purchased separately from MB outlets.
Details on my site http://homepage.ntlworld.com/albert.rowe
lofty is offline   Reply With Quote
