Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Old 07-22-2005, 07:54 AM   #1 (permalink)
SD1
Date registered: Jul 2005
Emergency Brake Assist
The Emergency Brake Assist light comes on even on light braking when the temperature is below 19C.
The Mercedes ageng said it was the switch on the Servo. The Servo would have to be replaced at a cost of £400 as the switch was not a spare part!
Having obtained a new switch, a Mercedes Spare part and fitted it, the same fault is present.
The Brakes work perfectly.
Any ideas?
SD
SD1 is offline   Reply With Quote
Old 07-28-2005, 03:13 AM   #2 (permalink)
Shermio's Avatar
Date registered: Jul 2004
Send a message via MSN to Shermio
RE: Emergency Brake Assist
Unfortunatly, It's Just One Of Those Things That Happens... The Electronics In The A-Class Isn't The Sharpest, And Things Like Contact Point Could Be Eroded And May Cause Incomplete Circuits Some Times And Be Fine The Next... Hard To Say... Might Be Best To Get A Second Opinion That Doesn't Cost 400Pounds Cause They Are Stealerships... [:(!]
d(O_o)b
Shermio
http://perpetualdreamer.deviantart.com
1999 Mercedes A160 Avantgarde RS (SOLD)
1996 Mercedes E230 (First W210 E-Class In New Zealand)
2002 Mazda MX-5 SE (1 Of Only 15 In New Zealand)
Shermio is offline   Reply With Quote
Old 08-05-2005, 11:28 PM   #3 (permalink)
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124
Send a message via ICQ to benzboyz Send a message via AIM to benzboyz Send a message via MSN to benzboyz Send a message via Yahoo to benzboyz
might be the booster causing the BAS to fail (relase swicth). Brake system is not affected when BAS fail, the assist to brake more force in an event of sudden braking is not functioning. Your dealer can find out what really causing this thru the Star Diagnosis fault code.
benzboyz is offline   Reply With Quote
