Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Sedan Forums > W168 A-Class
Old 06-26-2005, 02:33 PM   #1 (permalink)
Date registered: Jun 2005
Send a message via Yahoo to gbenga
A160 doesn't go past 30mph!
I recently bought a year 2000 X reg A160 semi auto, the car drives well but it occasionally refuses to go past 30MPH!! even if you depress the accelerator fully. This happens once in a while.Any ideas? I have parked it until I have time to take it to a merc garage. will really appreciate your input. thanks
gbenga is offline   Reply With Quote
Old 07-11-2005, 07:47 AM   #2 (permalink)
Date registered: Jul 2005
RE: A160 doesn't go past 30mph!
Hi, This has happened to us too. In fact this is the second A class where we have the same fault. It's with the dealer now.
Do you know any more.
A Fredman is offline   Reply With Quote
Old 07-14-2005, 02:05 AM   #3 (permalink)
barret's Avatar
Maybe the ignition module is defective. Then the engine runs in an emergency programme
www.2fast2furio.us
barret is offline   Reply With Quote
Old 07-15-2005, 07:46 PM   #4 (permalink)
Shermio's Avatar
Date registered: Jul 2004
Send a message via MSN to Shermio
Ditto...
Could Be Anything From Stuff Clogging The Intake To A ECU Malfunction... Best To Take It To The Stealership...[V]
d(O_o)b
Shermio
http://perpetualdreamer.deviantart.com
1999 Mercedes A160 Avantgarde RS (SOLD)
1996 Mercedes E230 (First W210 E-Class In New Zealand)
2002 Mazda MX-5 SE (1 Of Only 15 In New Zealand)
Shermio is offline   Reply With Quote
Old 07-29-2005, 02:41 AM   #5 (permalink)
benzboyz's Avatar
Vehicle: W124
Send a message via ICQ to benzboyz Send a message via AIM to benzboyz Send a message via MSN to benzboyz Send a message via Yahoo to benzboyz
what about the speed limiter maybe it is on?
benzboyz is offline   Reply With Quote
Old 07-29-2005, 05:05 PM   #6 (permalink)
Shermio's Avatar
Correct Me If Im Wrong But The Speed Limiter Can't Be Activated Until It Goes Past 60Km/h Which Is Like 37Miles...
The 30 Miles Seems To Me Like It's The Save Mode... [?]
Old 07-31-2005, 07:50 PM   #7 (permalink)
benzboyz's Avatar
Vehicle: W124
hmmmm, maybe I am wrong but here is the description of the function.
Old 07-31-2005, 09:15 PM   #8 (permalink)
benzboyz's Avatar
Vehicle: W124
Old 08-28-2005, 12:53 PM   #9 (permalink)
SD1
Check Battery Voltage.
If the Battery Volts are only 10-11Volts this will cause this problem.
SD1 is offline   Reply With Quote
