Locking the car ... - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-25-2012, 11:33 AM Thread Starter
Date registered: Feb 2012
Locking the car ...
Here's the steps and question:
1. push start/stop button to shut off engine.
2. Leave car close door - then re-open door.
3. push start/stop button (without pressing brake) - radio/dash come on.
4. leave car again - radio stays on.
5. Try to lock car with wireless key - car will not lock.
Only by re-starting the engine and shutting it down will all stuff go off and car lock.
Is there another way to shut everything down and lock the car?
Thanks
mjz3348 is offline
post #2 of 6 (permalink) Old 11-25-2012, 01:16 PM
Date registered: Jan 2012
Vehicle: 2013 E550 Cab 2016 E350 2009 CLK 320 Cab
Quoted: 4 Post(s)
Shut off engine
Get out and close door, have the key with you.
Rub your hand across the door handle - car will lock.
NatK is offline
post #3 of 6 (permalink) Old 11-25-2012, 01:24 PM
2013ML350W4's Avatar
Date registered: Nov 2012
Agree on NatK's description of the process.
Southern Panhandle
2013ML350W4 is offline
post #4 of 6 (permalink) Old 11-25-2012, 02:23 PM Thread Starter
Originally Posted by NatK View Post
Shut off engine
That didn't work. Recall. Engine was shut off - then the "start" button was pushed without foot on brake to start the engine. Instead - all of the electronics came on. Leaving the car and trying to lock it is not possible. I had to start the car again and then shut if off in order to exit and lock.
mjz3348 is offline
post #5 of 6 (permalink) Old 11-25-2012, 03:11 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 131 Post(s)
Yes - the 1st push/stop shut down the engine and leaving the car you will be able to lock it.
I have no idea why you 2nd push/start-wake up the car - which requires a 3rd push/stop to shut the car down properly.
Your 2nd pus/start-wakeup is causing the issue - your MB is fine.
fabbrisd1 is offline
post #6 of 6 (permalink) Old 11-25-2012, 03:28 PM
Date registered: May 2012
Vehicle: 2012 ML350Bluetec, 2013 A200 Exclusive, 2009 ML350CDI(sold), 2003 Aston Martin DB7VV.
3. push start/stop button (without pressing brake) - radio/dash come on. (ignition is now in position 1)
5. push start/stop button (without pressing brake) - ignition is now in position 2.
6. push start/stop button (without pressing brake) - ignition is now off
7. close door and you can lock it by any means.
You can do steps 5 & 6 reaching in through the open door.
iankayem is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
