Is there a fuse for the alternator on ml500 2006. My alternator turning with an engine but don't give out any power no power how can I make sure I measure on the main battery with car running its on battery also under the hood where the red cable from the alternator go on the power divider still battery voltage which was 11.something at the time and car shuts down say low power or voltage please let me know if something I can look for thanks
The alternator can be repaired. First it must be removed and tested to discover the exact problem.
The voltage regulator can be replaced, which is a smaller part attached to the alternator.
If you managed to get your car home, if you fully charge the battery using an alternative power source, you should be able to drive it to a nearby workshop. Unless you want to DIY.
