ML 320 164 airmatic problems - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-23-2013, 08:58 AM Thread Starter
Date registered: May 2008
Hi Everyone 2006 (January) 320 ml cdi having problems with the air suspension!
the suspension is right down,taken the compressor off and tested it out of the car,runs fine-put it on the car and runs for a while and then stops.but the suspension does not move.have scanned it for faults and no faults recorded.
did a live data test without the engine running but ignition on and gave the following readings
terminal30 11.78v -ternminal 87 on -left front sensor 3.67v and -67mm front r sensor 1.39v -64mm rear left 0.92v -116mm rear rt 4.31v -116mm left front accel sensor 2509.8 mv right 2509.8mv airmatic pressure sensor 10.43 bar compressopr operating time 1075561sek lock pos off any ideas ?
FIXED
Should have looked more closely at rear bags-both leaking when weight on
thanks anyway for reading this
mikespain is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
