'08 320 CDI limp mode - Page 2 - Mercedes-Benz Forum
post #11 of 52 (permalink) Old 07-08-2013, 11:19 AM
N4HHE's Avatar
Date registered: Mar 2012
Vehicle: 2009 ML320 Bluetec, 2013 Tesla Model S 85
Quoted: 18 Post(s)
Originally Posted by w2hmh View Post
The second time, now (170,000 mi), the dealer told me that the M55 intake inlet port shut off motor was bad and it needed to be replaced along with the intake manifolds($3,700) because the intake manifold valves were clogged with carbon hence causing the motor to short out. I opted to investigate myself. The shut off motor is indeed shorted (blown fuse #104), however the intake manifold valves are not clogged...the motor was shorted out due to oil leaking from turbo seal. I am currently in process of replacing the motor($150) myself. This is a rather involved job and not for the faint of heart.
IIRC Jeep CRD owners have found one can put a resistor across a couple of pins on the "swirl motor" harness to keep the ECU happy with failed motors with no noticeable effect on drivability or MPG.
Any electronics hobbyist should have the 1/4 watt resistor, they cost under a penny each in 200 count bags, or 5 for $2 at Radio Shack.
N4HHE is offline
post #12 of 52 (permalink) Old 07-08-2013, 06:42 PM Thread Starter
Date registered: Feb 2010
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 100 Post(s)
I have had similar problems with my '08 ML320cdi. Once at around 140,000 mi the dealer told me that the DPF was plugged and I needed to have it replaced ($3,600). I opted not to replace and replaced the differential sensor($53) myself which is located underneath the vehicle near the DPF. this solved my problem!
W2HMH, what led you to suspect the differential sensor?
Skippy
Sent from AutoGuide.com App
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
SkippyJasper is offline
post #13 of 52 (permalink) Old 07-08-2013, 06:59 PM Thread Starter
Quoted: 100 Post(s)
The Mrs drove it to work with the CEL on, but normal power. It's a 15 mile trip at highway speed. The CEL was off on the return trip.
I took it out after dinner. It's about a mile to the entrance ramp, then I went to 75 and set it on cruise.
I monitored the 'miles to empty' display which went from 305 to 295 by mile 4 and then steadily rose. I turned around at mile 10ish and the display was at 380 when I pulled into the drive at home.
Skippy
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
post #14 of 52 (permalink) Old 07-08-2013, 08:57 PM
Date registered: Jun 2013
Have you replace the crankshaft position sensor?
geebra is offline
post #15 of 52 (permalink) Old 07-09-2013, 09:39 AM
Date registered: Dec 2007
Skippy,
I drive my ML hard all the time. 5 x 120mi round trip for a weekly commute of 600mi 85% of which is at 70mph+. With this in mind I just couldn't understand how the DPF could be clogged.....if anyone is heating this thing up and blowing it out....I must surely be one. I researched the DPF system's operation and discovered that there is a pressure differential sensor between the input and output sides of the DPF...this must be how the computer senses that the DPF needs to be cleaned or if a cleaning cycle does not fix it: BAD.....what if the sensor is bad?...I gambled for $53 and won.
_________________________________
1985 Volvo Diesel Wagon 320,000 (sold)
1983 300TD 385,000 mi (sold)
1987 300D 280,000 mi (sold)
2008 ML320 CDI 190,000 mi
1991 350SD 167,000 mi
w2hmh is offline
post #16 of 52 (permalink) Old 07-09-2013, 09:59 AM
N4HHE's Avatar
Quoted: 18 Post(s)
Skippy,
Excellent reasoning and diagnosis. Plus it wasn't really a gamble because anyone putting a $3000 DPF in the truck would probably insist on replacing all the related sensors just the same as they would replace the gaskets.
I haven't seen the details or heard for certain but have heard from several sources that Ford has an off-vehicle DPF cleaning procedure. But the labor is enough to make the process a gamble. Replacement is the safe bet.
N4HHE is offline
post #17 of 52 (permalink) Old 07-09-2013, 10:17 AM Thread Starter
Quoted: 100 Post(s)
I like the logic and it sounds like it worked. Anything obvious with the old sensor once you had it out? Burned, rusty, cracked, etc?
I appreciate your time on this.
Skippy
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
post #18 of 52 (permalink) Old 07-09-2013, 04:18 PM Thread Starter
Quoted: 100 Post(s)
Thanks for the thought.
I believe it was replaced early on in its life. Truck grew up about 150 miles from my location.
The records I have do not show this, but my local dealer said it was performed.
Of course the next question would be 'what is expected life of a CPS?' On the W210 gassers it's 100K miles.
Skippy
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
post #19 of 52 (permalink) Old 07-16-2013, 10:02 AM
Skippy
Skippy,
Nothing obviously wrong with the sensor (not cracked, burnt, rusty, etc.)...however now that you have opened the door....there was a fresh bright red mark drawn across the sensor label (looked like it was from a Sharpie)...I have no proof, however I am very suspicious that the bad sensor was identified (the red mark) and the dealer chose to tell me to replace the DPF...bad call on their part.....I have since provided feedback to MBUSA who in turn had the dealer contact me. Without going into too much detail here, as this story has much to tell, the dealer(Intercar, Newton, NJ) knows he did wrong and that he has lost a customer for good.
w2hmh is offline
post #20 of 52 (permalink) Old 07-16-2013, 10:52 AM Thread Starter
Quoted: 100 Post(s)
Yikes!
I'll take a look at mine and let you know if there's a line on it. 😏
The EPC shows an updated sensor (i.e. replaced by .....).
I'm thinking of paying for a days worth of WIS to get the diagnostics on the DPF system. I read another posting where the 'temperature' sensor for the DPF was replaced which cured a problem.
Skippy
Skippy,
Current Garage
'08 320ML
'07 E320 BlueTec
'98 E320
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
