Fan after engine is off? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 12-12-2011, 09:59 AM Thread Starter
Date registered: Mar 2011
Vehicle: ml350 2011 White,Ash int. 2013 SLK 250
2011 ML350 After I shut off engine and return to garage a few minutes later, I hear a fan under hood running.If I open passenger door,fan stops.Does not happen all the time.Seems to happen after running A/C .Any ideas?
buckybr is offline
post #2 of 4 (permalink) Old 12-12-2011, 06:17 PM
Date registered: May 2010
Vehicle: '11 ML350
same issue here. Seems like this topic has come up before but now I can't recall any of the comments.
FredGarvin is offline
post #3 of 4 (permalink) Old 12-13-2011, 07:12 AM
roadrutz's Avatar
Date registered: Sep 2008
Vehicle: '09 ML550, '12 BMW 650i Cab (lucky wife)
This is just a guess, but if it happens after using the A/C I would surmise that perhaps there is an auxiliary fan that runs in order to prevent water build-up in the condenser, which is what provides an environment for the growth of bacteria, leading to that horrible 'sock' smell you sometimes get.
Later: Not a bad guess! See DougY's comment below.
roadrutz is offline
post #4 of 4 (permalink) Old 12-13-2011, 02:53 PM
DougY's Avatar
Date registered: Feb 2011
Vehicle: '10 E350 coupe; SOLD--'10 C300; SOLD--'10 ML
Quoted: 4 Post(s)
There is the REST feature which will keep veh interior warm after the veh is shut off. YOU activate it by hitting AC/rest button and it blows warm air until engine temp drops or battery gets low (safety part)
I thought it was malfunctioning because I had NOT turned it on but heard the fan running in garage.
When I queried the dealer, they explained there was a feature to run fan to clear condensation from the system.
It wasn't mentioned in book so I had no idea.
DougY is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    W203- Is a 2003 engine compatible with a 2006? can I do a full/clean engine swap? TWINBENZS1989 W203 C-Class 1 10-05-2011 04:58 PM
    Chopards Engine Watch Channels Luxury Autos Engine Block AutoGuide.com AutoGuide.Com News 0 06-10-2011 11:50 AM
    Request for Advice on Engine Driveability Problem on New Engine Install (Long) SMinn560SL R/C107 SL/SLC Class 2 01-04-2006 05:00 AM
    wierd engine behavior w/ check engine light, dealer unable to solve spovilaitis R170 SLK-Class 6 12-12-2003 08:05 PM
    Say you have a 2.3 engine or a 3.2 engine. Is that called engine size ? engine capacity ? Vince R170 SLK-Class 4 11-01-2001 08:14 PM
