Premium Gas Vs Regular for ML - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 10-13-2010, 10:42 AM Thread Starter
Date registered: Jul 2010
Vehicle: ML350
Post Premium Gas Vs Regular for ML
In US, it is recommended that we use Premium fuel for ML350. What's the difference in using Regular instead of Premium Gas, what all the issues it might cause?
Any inputs?
Jamesbond_007 is offline
post #2 of 9 (permalink) Old 10-13-2010, 11:58 AM
Date registered: Aug 2007
Vehicle: 2004 SL500 R230 White/Beige
USATODAY.com - Why use premium gas when regular will do?
Premium isn't necessary anymore, but the engines are very highly tuned. I've heard of Mercedes engineers using regular, so it can't be that bad. The main reason for the requirement of premium is that bad gas could cause major damage, and premium is less likely to be bad. Also, the lowest octane gas in Europe, where they are designed, is 95, so our premium is already slightly lower.
Zampolit is offline
post #3 of 9 (permalink) Old 10-13-2010, 12:31 PM Thread Starter
Vehicle: ML350
Thanks for the reply Zampolit.
I just noticed there are some threads in the past discussing about this. My apologies for opening a new one.
post #4 of 9 (permalink) Old 10-13-2010, 01:08 PM
aggst1's Avatar
Date registered: Dec 2008
Vehicle: GL450, R500 traded, ML350 sold
So imagine how bad it is to use regular here in the US since our premium is actually of slightly lower octane levels.
Also, when using regular your motor becomes less efficient.
aggst1 is offline
post #5 of 9 (permalink) Old 10-13-2010, 02:14 PM
I asked the service manager at the local dealership once, and he said that Mercedes specifically says that they can't use the octane of gas used to determine warranty eligibility because the computer systems on the cars are guaranteed to compensate in the case that you accidentally fill up with it. That said, I use mid range simply for the fact that at the altitude I live in makes it a better mix for the amount of oxygen in the air, and my mileage is actually slightly better as a result. whenever I go to sea level I fill up with premium first.
Zampolit is offline
post #6 of 9 (permalink) Old 10-13-2010, 05:18 PM
Date registered: Oct 2010
I thought the same thing, see i got a pre owned 07 ml, and the salesman told me that i can use regular gas. Which was kind of fishy to me because hes the first person who told me to use regular gas. I was always told by friends and family and some research that its usually best to follow what the manual recommends. Im sure that regular gas would work but i feel like if i want my car to last long and treat me well, i have to give it the best of things. Especially with gas. I've also found out that the main benefits of using premium gas is improved gas mileage, cleaner engine, and optimum performance. One of my buddies always uses premium, and one time he let one of our friends drive his car and when they filled it up, the gas man mistakenly put regular in it. He told me that he noticed a difference in power. I didnt get to feel it because i was used to regular gas before i got the ML350. But like they say "take care of your car and itll take care of you".
EDIT: I think that the salesman told me to use regular gas because he thought that i would be discouraged from buying it if i knew that i had to spend money on gas...smh what a tool...i think i knew more about cars than that bloke did.
CHRi5 is offline
post #7 of 9 (permalink) Old 10-14-2010, 08:38 AM
roadrutz's Avatar
Date registered: Sep 2008
Vehicle: '09 ML550, '12 BMW 650i Cab (lucky wife)
I don't understand your logic. The ECU meters the correct amount of gas based on the MASS of incoming air, not the volume (hence 'mass airflow sensor'). A given volume of air at high altitude will have less mass than the same volume at sea level, hence the reason why naturally aspirated engines produce less power at height. But for a given mass of air, premium gas will always produce more power as the ECU doesn't have to retard ignition the way it does with lower octane.
Or is my memory of physics getting rusty in my old age?
roadrutz is offline
post #8 of 9 (permalink) Old 10-14-2010, 10:20 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Any inputs?
There's a difference between "recommended" and "specified."
Premium is specified by Mercedes.
It's not just "US," either.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #9 of 9 (permalink) Old 10-15-2010, 07:32 AM
Date registered: Nov 2008
it has nothing to do with oxygen as the OP said, but you are on the right path here talking about volume and mass. essentially at higher altitudes, air pressure is lower, and compression is therefore lower inside the engine, which means that high octane isn't necessary. it wouldn't result in BETTER mileage using mid grade instead of premium, but it would be AS good
ninjajim4 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    Regular vs premium gas - Is it a myth? lorryfan W163 M-Class 48 07-19-2011 01:47 PM
    Premium vs Regular Gas BENZ REB W211 E-Class 109 04-05-2010 02:01 AM
    Premium vs. Regular unleaded gas alexkocs General Mercedes-Benz 22 09-02-2009 05:58 PM
    Regular Gas insead of Premium Gas leetec W210 E-Class 46 08-12-2008 12:09 AM
    Gas: Regular or Premium? offroadwarrior Off-Topic 18 04-17-2006 11:12 AM
