ML350 Studded Running Boards - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-11-2010, 08:46 AM Thread Starter
MCF
Date registered: May 2009
1. If a 2010 ML350 comes with running boards, is it easy to remove them if you choose to do so at a later date and will the ML350 look just like those that did not come with the running boards?
2. A dealer is getting in an ML350 that meets all my requirements except it does not come from the factory with running boards installed. THe dealer wants $1500 to install them. This seems high to me. Thoughts?
3. If the dealer puts them on, will it look exactly like if the factory did and if the answer to question 1 is yes, will I also be able to remove them if I choose to do so in the future if the dealer puts them on?
4. Lastly, can you get these running boards and put them on yourself?
MCF is offline
post #2 of 11 (permalink) Old 02-11-2010, 09:41 AM
Date registered: Dec 2008
Vehicle: 2008 ML350 Iridium/Ash
No
High
Yes
Yes
They can be installed later, but it is not simple. There are trim pieces that need to go on after the boards are removed (and vice versa). Many of the retainer clips have one life. It can be done, it will look factory either way, but it is not simple to do. I bought a set from MBZ for $761.00 and, without instructions, installed them myself in about 3 hours and 2 beers. If I can....
Also, if you search you'll find quite a bit of stuff. Good luck, Brian
mamasml is offline
post #3 of 11 (permalink) Old 02-11-2010, 09:47 AM
audimotion's Avatar
Date registered: Oct 2009
Vehicle: 12 ML350 Bluetec pkg 2, 08 BMW 135i, 2012 F250 PS Diesel
1. Yes you can remove them. You will need the lower plastic peices to cover what you remove though. In other words, if you buy then ML without and you want to install OEM running boards, you will have to remove the in place covers to accomodate the new running boards.
2. That seems a bit high, but most say dealer gets around 800-1000 for the running boards and a couple hrs labor.
3. Yes it will look like factory installed boards. They are OEM boards, just not installed at factory.
4. Yes, I have been looking for either a used set or a discounted set from a MB dealer. They are a bit expensive, but my kids could really use the extra step. Search this forum for more info on the running boards. I believe there is even a DIY step by step as well.
audimotion is offline
post #4 of 11 (permalink) Old 02-11-2010, 11:39 AM Thread Starter
MCF
Thanks guys. So if you get one with the boards on, is it possible to buy only the trim pieces that are needed if you decide to take the running boards off?
MCF is offline
post #5 of 11 (permalink) Old 02-11-2010, 11:42 AM
audimotion's Avatar
Shouldn't be a problem...MB dealer parts dept. or an auto body shop should be able to get the parts you need.
post #6 of 11 (permalink) Old 02-11-2010, 01:39 PM
If the car comes w/out boards, it has a plastic lower rocker panel molding that pops off and is replaced by the running board. It takes a special tool to do this without breaking the tabs off, thus rendering the rocker molding unusable.
If it has boards and they are removed, the rocker plastic can be purchased for installation.
Best bet, by far...decide now if you want them or not, and buy accordingly.
mamasml is offline
post #7 of 11 (permalink) Old 02-11-2010, 01:48 PM
Vehicle: ML550, W212 E350 4 matic, 1966 Corvette C2 convt.
Quite frankly I think they are worthless. My ML550 came with them as standard and could not be ordered without them. I find them difficult to clean as dirt gets ingrained in the aluminum and they serve no useful purpose at all. I step over them each time I enter or exit the vehicle and they are not even deep enough to place your foot on should one wish to use them as a step.
sosh is offline
post #8 of 11 (permalink) Old 02-11-2010, 04:22 PM
Date registered: Dec 2009
Vehicle: 2006 c280, 2009 320 ML BT, 2011 ML 550 Grand Edition
Send a message via Skype™ to morbid angel
indeed it is true. I wanted them when I was getting my ML but the dealer talked me out of it. He said exactly those things you mentioned he also said that 90% of the customers who get them want them removed after the fact.
morbid angel is offline
post #9 of 11 (permalink) Old 02-11-2010, 06:36 PM
90%....seems more threads ask about putting them on than taking them off...
Either way, you either like them, or you don't. Blonde or brunette.
Above their limited use (or need) to get in/out of the ML, I find them helpful when:
washing the car (roof and sunrood glass)
de-icing the windshield
cleaning the windshield
loading skis/snowboards/gear on the roof rack
minimizing rock chips/sand pits in winter conditions
and, IMHO, they look sporty.
Plus, wife likes them (her car), and that alone is worth the price of admission.
mamasml is offline
post #10 of 11 (permalink) Old 02-11-2010, 07:07 PM
audimotion's Avatar
I'm sure they would be wide enough for a child foot. That is the main reason for me to want them. Our 3 and 6 yr old have a hard time climbing in and I'm sure the boards would help alot. I do feel they would be somewhat useless for an adult unless you would use the roof rack often. And of course, they do look good!
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    running boards taeandji X164 GL-Class 2 02-05-2010 09:06 PM
    2006 ML350 running boards / side step bar google9 W164 M-Class 0 09-05-2008 10:11 PM
    2008 ml350 oem running boards hardcashsab31 For Sale/Wanted/Trade/Giveaway 0 08-30-2008 07:59 AM
    need running boards roughyear W164 M-Class 2 11-10-2006 02:47 PM
    Running boards BordeauxBentz W163 M-Class 7 08-15-2005 11:38 AM
