» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 10-30-2009, 09:01 AM   #21 (permalink)
Date registered: Oct 2009
Send a message via Skype™ to V0v4ik
Thank you for your attention to me!
Wheel Alignment
V0v4ik is offline   Reply With Quote
Old 10-30-2009, 09:22 AM   #22 (permalink)
I think here, "the shoe pinches"
I could be wrong.
Old 11-03-2009, 01:01 AM   #23 (permalink)
aleveran's Avatar
Vehicle: 06 ML350
It might be gridding the insides on turns. As you know the alignment is done when wheels are straight. Do you hear any gridding noise the turning?
Sasha from San Francisco (originally from Odessa) ;-)
Best Regards,
Alex
aleveran is offline   Reply With Quote
Old 11-03-2009, 12:14 PM   #24 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Originally Posted by BigKutta View Post
I suggest you always wear rubber for your protection...
I'm thinking stay away from those where rubbers required.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport Pkg. smoky granite metallic/gray
2002 Jeep KJ 4wd Sport white/gray
MB-SV is offline   Reply With Quote
Old 11-05-2009, 04:21 AM   #25 (permalink)
I am originally from Nikolaev ))))
Old 11-06-2009, 10:06 PM   #26 (permalink)
Date registered: Aug 2009
Vehicle: 2006 ML350
I have never seen an all wheel drive SUV with different size tires on the front and back. The tire sizes you state are on the ml have different diameters/radius' not alot of difference but a differance none the less
Best way to check what tires are recommended is to look at the tire/rim information in the door jam, If you bought the vehicle used maybe a previous owner threw on a mis-matched set of tires just to sell it.
255/50/19= 29.04 in. diameter
285/45/19= 29.10 in. diameter
different tire manufacturers sizes may very
correction,
265/50/19= 29.43 in diameter
and that is even worse then numbers above, and in my opinion way out of spec for an AWD vehicle
DAN.505 is offline   Reply With Quote
Old 11-07-2009, 07:14 AM   #27 (permalink)
If you have never seen, it does not mean that it can not beML 500 4MATIC
Old 11-07-2009, 08:00 AM   #28 (permalink)
Vehicle: 2006 ML350
Originally Posted by V0v4ik View Post
Unfortunately Tire rotation is not possible to make,because different size tires.
Front 265/50/19 Rear 285/45/19.Indicator lights ESP.
The tire sizes you say you have on your car are not the recommended size from the MB web site you linked to, unless it was a typo.
And you are correct, if I have never seen it, it doesn't mean it isn't possible
and for that matter, don't believe everything you read either.
I would be looking at tire replacement before I started rebuilding the front end.
If the front end is wore out at 100K maybe the car was used for baja rally's,
I think MB builds cars that last longer than 100K under normal driving conditions.
Old 11-07-2009, 10:18 AM   #29 (permalink)
Front 265/50/19 Rear 285/45/19,this is a misprint.Front 255/50/19 Rear 285/45/19-so correctly.
If you look at my profile, you will see where my location.100K it is not for our roads.)))
Old 11-07-2009, 10:45 AM   #30 (permalink)
Mileage 70 000 km
This are our roads )))
Should you wear a condom? Jayhawk Off-Topic 9 07-16-2009 11:02 AM
Rubber, rubbers, and more rubber... thebenzbar W123 E,CE,D,CD,TD,TE Class 28 12-22-2008 07:11 AM
rubber OEM rubber mats Bigburgundy W163 M-Class 5 01-06-2008 05:13 PM
Do you wear your seatbelt? Jamison Off-Topic 15 05-22-2004 06:35 PM
