AdBlue sources for DIY refills - Benzworld.org - Mercedes-Benz Discussion Forum
» Auto Insurance
» Featured Product
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 07-17-2009, 09:34 PM   #1 (permalink)
drivbiwire's Avatar
Date registered: Mar 2006
Vehicle: 2006 E320 CDI, 2009 ML320 Bluetec, 2009 GL320 Bluetec
More information than you really wanted to know...but should know!
Mercedes Benz Selective Catalytic Reduction (SCR) additive Requirement:
-ISO 22241
Other key specifications for other AdBlue are:
-AUS 32
-DIN 70070
AdBlue® is a 32,5% solution of high-purity urea, used in Euro 4 and 5 vehicles' additional tanks. That permit to reduce emissions of oxides of nitrogen (NOx) from the exhaust of diesel vehicles, by SCR technology (selective catalytic reduction); about the 85% of thes emissions are converted by catalytic reaction into benign nitrogen gas and water, not dangerous for nature.
In the beginning AdBlue® (that can be also called "AUS32", Aqueous Urea Solution 32.5%) must respect some standards: DIN 70070 (quality standard) and DIN 70071 (analytical standard). DIN means "Deutsches Institut fur Normung".
-ISO 22241-1 Quality requirements, specifies the quality characteristics of AdBlue needed to operate the SCR system on your vehicle. It is a final, published International Standard.
-ISO 22241-2 Test methods, specifies test methods required for determination of the quality characteristics of AdBlue. It is also a published International Standard.
-ISO/DIS 22241-3 Handling, transportation and storing, describes how to deal with AdBlue in practice and in its content is much like the CEFIC Quality Assurance Guidance Document.
-ISO/DIS 22241-4 ISO/DIS 22241-4 Refilling interface, describes elements pertaining to refilling components.
Last two ISO are a 'Draft Industrial Standard', and will be published soon.
To assure a good working of AdBlue® storage and dispensing systems and of vehicles with SCR system, it's very important to use only AdBlue® products that match with ISO standards
At the moment the used standard for AdBlue® is ISO 22241 2008/9.
Per Mercedes maintenance Manual Page: 13 "Emissions System Maintenance":
Only use AdBlue® complying with
ISO 22241. Do not add special additives to
AdBlue® and do not dilute AdBlue® with water.
Otherwise, the BlueTEC exhaust gas aftertreatment
system could be damaged.
For the DIY servicing I have found a wide range of prices for the AdBlue or "Urea" additive. From my local dealer the price for 2 liters is $11.00 USD. They will not sell it in bulk ie 5 gallons at a time but only with a full service and even then are unable to break it down on a per liter basis for just the AdBlue additive.
DISCLAIMER: Improper filling and contamination of the AdBlue system WILL result in failure and EXPENSIVE damage to the emissions systems! Any attempt to repair, refill or tend to the system MUST be done with every reasonable measure to insure not external contaminant enters the AdBlue system! NEVER mix anything with the AdBlue additive! The system detects actual NOx output, therefore additive with ONLY the appropriate ISO 22241 Approval can be used to insure proper dosing of the catalysts. Diluting the additive WILL result in damage to the catalysts and a very expensive repair bill.
With that said, here is a listing of suppliers of the AdBlue additive:
http://www.worldimpex.com/parts/genu...ea_934647.html
IMPEX SKU # 934647
GENUINE PART
"Diesel Exhaust Fluid"
Compliance Standards:
-ISO 22241
-AUS 32
-DIN 70070
-ALDEHYDE FREE
Composition: UREA
OEM part number VW/Audi: GUS-052-910-A3 / GUS052910A3 )
OEM Mercedes Equivalant part Number: 004-989-04-20-12
List Price: $14.85 :: Impex Price: $12.83
Verfied to be a quantity of: 9.46L / 2.5 US GAL
NOTE: This can be purchased at any local VW/AUDI dealer
I will continue to add to this as I find more suppliers.
DB
drivbiwire is offline   Reply With Quote
Old 02-17-2010, 04:37 PM   #2 (permalink)
Date registered: Oct 2009
Vehicle: 2009 R-320 Bluetec
DB, Pilot truck stops...........Adblue sold as DEF (Diesel Emissions Fluid) same ISO...$13.99 for 2.5 gallons.
andyamit is offline   Reply With Quote
Old 02-19-2010, 06:41 PM   #3 (permalink)
Ox8xO's Avatar
Date registered: Jul 2009
Vehicle: W164
So how and how often do you refill it? And where is the pee tank located?
Ox8xO is offline   Reply With Quote
Old 02-22-2010, 12:43 PM   #4 (permalink)
rdf48's Avatar
Vehicle: 07 ML 320 CDI, 89 420 SEL+82 300 SD
Send a message via MSN to rdf48 Send a message via Skype™ to rdf48
About $5 bucks a gallon for water with a handfull of Urea,sounds like a good way to make a killing,wished I was in that business.
rdf48 is offline   Reply With Quote
Old 02-22-2010, 04:17 PM   #5 (permalink)
Date registered: Aug 2009
Vehicle: 2009 ML320 - Iridium Silver, Black MB-tex, Premium 2 package
almost made the mistake by buying online, $59 for 4 bottles and $69 to ship to house.. I think I will just go to a VW dealer and get it there...
willie
2009 ML320 Bluetec - Iridium Silver/Black MB Tex
Premium 2 package, Navigation, Headrest TV
ocwill1 is offline   Reply With Quote
Old 05-13-2010, 10:20 PM   #6 (permalink)
Date registered: May 2010
Vehicle: 2009 ML320 Bluetec
What is the Genuine Mercedes Bluetec UREA part number?
What is the part number for BMW that is compatible with MB?
sesmith72 is offline   Reply With Quote
Old 03-16-2011, 11:27 AM   #7 (permalink)
Date registered: Jul 2007
AdBlue Pricing
I live in MN, just called VW and they quoted $8 for 0.5gallon, then Mercedes who said it was $9 for the same. My GL has a 9.5 gallon tank but at 10,000 miles should only need 7gallons to fill it up (according to the dealer). Nice video on you tube shows how easy it is to do youself (about 4mins in).
Dealer quoted $250 to fill the tank at the 10k service, so even if I buy it in 1/2 gallon jugs saves $170.
JeremyFripp is offline   Reply With Quote
Old 03-16-2011, 12:27 PM   #8 (permalink)
YouTube - Mercedes-Benz AdBlue Technology
Great video (from Europe) buy the DEF for $14 for 2.5 gals and a funnel to make it easy. (that's $2.8 for the 1/2 gallon). My R Class does 10,000 miles on 5 gals of Ad Blue (DEF).
Exactly the same ISO number - the dealers (MB,BMW & VW) are just trying to make a huge profit on those 2 liter bottles.
Old 06-06-2011, 06:03 PM   #9 (permalink)
Date registered: Jul 2008
Vehicle: 2009 ML320, 2006 E350
$22.00 Ad Blue refill
Today I purchased two, 2.5 gallon jugs at Autozone for $11.00 each. I also bought a 1 liter bottle from The VW dealer for $8.00. I just wanted to try the official bottle with the no spill neck, The official bottle worked great. I used about four gallons altogether.
I broke the lock on the neck of the official bottle so I can refill it from the 2.5 gallon jug and make topping off the reservoir allot cleaner next time. It would be great to get the no spill neck fitting on the 2.5 gallon jug. Hey for the money I saved I don t mind the extra step.
ejanselm is offline   Reply With Quote
Old 06-07-2011, 10:09 AM   #10 (permalink)
Date registered: Nov 2008
Vehicle: 1997 E420, 2006 E350, 2009 ML320 Bluetec, 2002 E320 4matic Wagon
+1 on this I did the same thing after buying a 2.5 gallon jug at a truck stop. Then I found it for $11.50 at Wal-mart...I highly recommend using the official bottle but filling it from the larger container. You DO NOT want to spill the Adblue as it will cause electrical issues with connections at the refill point and cause a mess in your MB.
Hopperb is offline   Reply With Quote
Bookmarks
AdBlue question (for you BlueTec guys) bumper W211 E-Class 11 09-10-2010 06:07 AM
Wiper Refills from Autohauz Kirill R170 SLK Class 2 04-22-2008 12:50 PM
wiper blade refills jeffinski W211 E-Class 4 05-06-2007 09:38 AM
Wiper refills cheapdanny W163 M-Class 16 12-13-2002 12:02 PM
Wiper Refills roy W163 M-Class 4 03-05-2002 03:11 AM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
