Cabin filter in 06 ML500 - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 05-18-2009, 11:40 AM Thread Starter
Date registered: Feb 2009
Has anyone changed the cabin filter in 06 ML500?
Reading in this forum, seems like it's only accessible through the glove compartment. But I see the filter access door under the hood (passenger side). Is it not possible to change through there? Do I have to take the glove compartment out?
Thanks.
David123 is offline
post #2 of 17 (permalink) Old 05-21-2009, 10:39 AM Thread Starter
Anyone, Please.
David123 is offline
post #3 of 17 (permalink) Old 05-24-2009, 06:58 AM
Date registered: Dec 2006
Vehicle: 07 ML350
cabin filter
you cannot access the cabin filter in the engine bay, instead you have to remove the glove box, 3 top torx screws, and 1 torx screw on the side (remove side panel of dash), and 3 torx screws at the bottom, then let the glove box hang since the cable of the cd changer is there, unclip the glove box lamp socket, and there you will see the filter cover, there will be two cabin filters to replace/clean.
BruNo
10 Bmw 740Li (F02)
07 ML350 Us Version (for sale)
11 Mini John Cooper Works
12 Range Rover Evoque Dynamic Si4 (on order)
bruno787 is offline
post #4 of 17 (permalink) Old 05-26-2009, 01:48 AM
Date registered: Feb 2006
Vehicle: 2006 ML 500
Cabin filter pics...
David123,
After opening the glove compartment you should see this as attached.
mcphere
Name:	Cabin Filter.jpg
mcphere is offline
post #5 of 17 (permalink) Old 07-19-2009, 07:47 AM
miked56's Avatar
Date registered: Feb 2007
Vehicle: 71 280se 3.5 Cab, 06 C230, 06 ML350
Does the side panel of the dash just snap out or is there some special trick to removing it?
Mike
miked56 is offline
post #6 of 17 (permalink) Old 07-20-2009, 03:42 PM
miked56's Avatar
Just finished the filter replacement. Very easy really. You'll need a T-20 Torx head for the screws and filters of course.
Remove the Fuse panel on the side of the dash by pulling the front top edge (I'll post pics later) There is one screw facing the front of the ML to remove
Remove the three Torx screws on the top front inside edge of the glove box. Need to have the door open. CAUTION, the one farthest right is different size than the other two.
Remove the three torx screws from the bottom of the glove box. They are located under the dash sow lay on your back and you'll see them.
With the glove box out you will see the cover as shown in #4. To get the cover (#2 in the diagram) just slide it to the left then pull forward. Very easy when I figured it out.
Pull the filters out. I vacuumed in the opening since there was bits still in there.
After inserting the new filters place the cover back on and slide it to the right. Put the screws in making sure the side screw flange is tight against the other half.
Hope this helps
Mike
miked56 is offline
post #7 of 17 (permalink) Old 08-07-2009, 01:04 PM
Date registered: Oct 2006
Vehicle: W164 ML500
Send a message via MSN to bondtbilisi Send a message via Skype™ to bondtbilisi
please post some pics
Hi,
sounds really easy. but some pics would be helpful
bondtbilisi is offline
post #8 of 17 (permalink) Old 08-13-2009, 09:07 AM
Date registered: May 2005
Vehicle: 2006 e320 cdi, 2006 ml350, 2008 ml320 cdi
Send a message via AIM to Cpt. Samir Send a message via Yahoo to Cpt. Samir
yup pics would help
Cpt. Samir is offline
post #9 of 17 (permalink) Old 08-14-2009, 01:27 PM
Date registered: Aug 2009
Vehicle: '06 ML 500
Really helpful guys...Thanks!
Rubliski is offline
post #10 of 17 (permalink) Old 08-29-2009, 11:11 PM
I appreciate this information. I will let you know how I make out with replacing the cabin filters on my '06 ML350 to put an end to the musty smell when turning on the AC.
DomNJ is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    S550 Oil Filter and Cabin Filter MB5504wd W221 S-Class 7 03-26-2012 09:48 PM
    2003 C230 Air Filter and Cabin Filter Replacement xlibe W203 C-Class 6 09-05-2008 11:45 AM
    Cabin air filter and dust filter snakoiler C208/A208 CLK-Class 4 05-05-2008 12:06 PM
    Cabin Filter cerritos W210 E-Class 17 12-24-2007 11:49 PM
    Need help for changing fuel filter and cabin filter... mhsu168 W220 S-Class 3 06-03-2007 02:28 PM
