Reset Maintenance Service Indicator - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-29-2008, 02:24 PM Thread Starter
Date registered: Dec 2008
Vehicle: 2007 ML320 CDI
ML 320 CDI
Does any one have any more sage advise on how to perform what should be a simple procedure ? I have down loaded the Reset Maintenance Service Indicator.PDF and carefully followed the procedure. . . No luck ! I've about worn out my Owners manual searching for instructions on resetting it.
Thanks !
On the fifth attempt I managed to get it reset per Reset Maintenance Service Indicator.PDF instructions. All this after a phone call to Mercedes USA where I was told only the dealer could reset it. I don't think that's a resource I be using in the future.
200%dave is offline
post #2 of 10 (permalink) Old 12-29-2008, 03:53 PM
Date registered: Mar 2007
Vehicle: 2007 Alpine Rain/Ash ML320 CDI
I usually finish the job, get cleaned up, grab a beer, get comfortable behind the wheel (in the garage of course), then with the reset procedures in hand, do the same thing as you did. After about five attempts (more or less) I get the menu up and can do the reset. But knowing it will take a few attempts, and the fact that I finished the job and have a beer in hand, I feel much better. That is the best feedback I can provide.
CJzBenz is offline
post #3 of 10 (permalink) Old 12-31-2008, 09:11 AM
Date registered: Jun 2006
Vehicle: 2000 ML 430, 2014 MLBluetec
Quoted: 5 Post(s)
As a future reference as folks try this, I want to add that it took me about 15-20 times to get mine rest last night. I really don't know how many times it took. Rather than have a beer in hand, I decided I would stay in the ML until the dam thing reset. I turned it off and on and kept hitting the rest button 3 times. Finally the voltage appeared and I was able to rest it.
My reward was a Brandy and soda, but I must admit I was concerned that I might be spending the night in the car.
Crazy how complicated this is, but at least I know it can be done!
For those in the future, just keep doing the procedure. It must be hard on pupose so it is not accidently done or to provide a source of revenue for the Dealer.
pmount is offline
post #4 of 10 (permalink) Old 12-31-2008, 09:33 AM
Yazovets!'s Avatar
Date registered: Feb 2006
Vehicle: 2014 ML350 Bluetec
Quoted: 2 Post(s)
You could also use a Scangauge. That thing can also read error codes when you get them.
2014 ML350 Bluetec | Teronite Grey | Black ARTICO Leather | Premium Package | Bi-Xenon Package | Driving Assistance Package | Weathertech Floorliners & Trunk Mat
Past: 2011 ML350 Bluetec, 2011 E550, 2008 ML320 CDI, 2004 ML500
Yazovets! is offline
post #5 of 10 (permalink) Old 12-31-2008, 10:26 AM
OK totally newbie question but why would you being resetting this anyway?ouldnt this be done by the dealer mechanics- if say the car was under warranty- I can see how if its not it would make sense to do it...but if it was under warranty is they are real need to do it...also what changes did you guys do that required you to change it- just curious thanks
Taurus106 is offline
post #6 of 10 (permalink) Old 12-31-2008, 10:52 AM
Vehicle: Mercedes ML 420 CDI
For me it's like this:
- i've made the first revision at 20 000 Km, not 30 000, but they forgot to reset Maintenance Service Indicator.
I've managed to get rid of it using the indications from the pdf (see attached file)
Courage is offline
post #7 of 10 (permalink) Old 12-31-2008, 01:38 PM Thread Starter
Response to Taurus106 question
My Maintenance Service Indicator said the vehicle was due for "Service C". I checked with the MB dealer's service department. For what is nothing more than a tricked up oil change they wanted $429. I bought the "fleece" oil filter on line for $12.95. The local Valvoline quick lube guys performed 80% of the stuff the MB dealer was promising to check and got me out the door for $85. But, they didn't know how to reset the Maintenance Service Indicator.
200%dave is offline
post #8 of 10 (permalink) Old 01-01-2009, 10:42 AM
When you do your own or have an independent mechanic do the maintenance is when you'd do the reset. It's not a big deal, just a little tedious and woun't hurt the warranty as long as the work is accomplished.
CJzBenz is offline
post #9 of 10 (permalink) Old 10-24-2009, 08:57 PM
Date registered: Oct 2009
Vehicle: 2007 CLK350 COUPE VIN: WDBTJ56HO7F220572
RESET 2008 C300
I have a 2008 C300 sedan. My buttons are different. It an OK with up,down, left and right. Can you explain the sequence so I can try it that way?
Thanks
Seajay
SEAJAY is offline
post #10 of 10 (permalink) Old 10-25-2009, 04:31 AM
Date registered: Feb 2007
Thanks
Seajay
Try this.
Doppelgänger is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    Service indicator reset markbaumel@yahoo.com W211 E-Class 21 02-25-2016 01:18 AM
    How do I reset the service indicator? vladee W163 M-Class 37 12-16-2015 09:19 AM
    reset my Service indicator Vince_E500 Audio & Telematics Forum 7 03-08-2007 05:30 PM
    How to Reset Maintenance Service Indicator shark22 R171 SLK-Class 1 10-26-2005 06:47 PM
    how to reset the service indicator vinceching W140 S-Class 2 04-21-2004 12:43 AM
