Tire Pressure Loss Warning System - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 11-08-2008, 05:24 AM Thread Starter
MY2008ML350's Avatar
Date registered: Mar 2008
In Canada, the ML has the Tire Pressure Loss Warning System (TPLWS). How is this different with the TPMS in the States? What PSI is TPLWS using for measurement? How is this calibrated?
2010 B200, Polar Silver, Premium Pkg
2008 ML350, Obsidian Black, Premium Pkg
2008 C300, Calcite White
2007 C230, 040 Black, Premium Pkg (gone)
MY2008ML350 is offline
post #2 of 13 (permalink) Old 11-08-2008, 07:18 AM
Date registered: Dec 2007
The Canadian system uses the computer to monitor wheel rotation speed, sensing the different speed of a low tire not actual pressure in the tire The other system uses actual pressure sensors on the wheels that monitor tire pressure.
1980 450sl traded in
1983 380sec sold
1989 300se traded in
2002 ML320 Gave to Family member
2008 ML320CDI /Full load (inc air susp) minus rear entertainment/ Pewter Silver Black leather
Vernl is offline
post #3 of 13 (permalink) Old 11-08-2008, 08:02 AM
Deutsch100's Avatar
Date registered: Jul 2008
Vehicle: 2011 GL550, 2011 G55 AMG, 2011 Range Rover Supercharged
For some reason, the Canadian ML gets Advanced TPMS. The USA version gets the very basic (old version). With the Advanced version, one can see the exact pressure on each wheel (a graphic model in the main instrument cluster). What's funny, is that for 2007/2008 Mercedes gave the G-Class the Advanced TPMS (a 30 year old model), while the all new for 2006 ML gets the crap old version (but for the USA). I'd love to know the reasoning for this. Also, why does Canada get the tilt down passenger mirror feature, and the ML, G, GL and R in the USA does not get this anymore (it was standard a year or so ago). So odd and maddening!!
Deutsch100 is offline
post #4 of 13 (permalink) Old 11-08-2008, 08:55 AM Thread Starter
Originally Posted by Deutsch100 View Post
...Also, why does Canada get the tilt down passenger mirror feature, and the ML, G, GL and R in the USA does not get this anymore (it was standard a year or so ago). So odd and maddening!!
Only available when you get the premium package.
One reason is probably our MLs cost more (about US$52000 equivalent for the base ML350)
post #5 of 13 (permalink) Old 11-08-2008, 08:58 AM Thread Starter
Originally Posted by Vernl View Post
...The other system uses actual pressure sensors on the wheels that monitor tire pressure.
Yes, the Canadian system is more advanced
You can have the equivalent of the old TPMS by purchasing from Canadian Tire now on sale for 50 bucks !
post #6 of 13 (permalink) Old 11-10-2008, 09:26 PM
Date registered: Jan 2007
Vehicle: 2005 C230K Sport Coupe 6-speed! And now a 2011 GLK 350 4Matic in Palladium Silver!
As far as I know, the Tire Pressure Loss Warning System, as stated above, calculates tire rotation to monitor pressure loss, and only tells you a tire is low and you need to find which one. A Tire Pressure Monitoring System has a transponder in each wheel that communicates with a central computer to warn exactly which tire is low. This specific system is non-serviceable unless you buy the handheld device that allows you to reset the vehicles TPMS computer. If the system shows a tire is low, you simply add the mising air and it resets itself. Another problem you may encounter is the location of the tires if you do a tire rotation. Again, you will need the handheld to reset it.
Whosdis is offline
post #7 of 13 (permalink) Old 11-11-2008, 06:54 AM
roadrutz's Avatar
Date registered: Sep 2008
Vehicle: '09 ML550, '12 BMW 650i Cab (lucky wife)
The TPLWS on my wife's M3 specifies which tire is low but doesn't say by how much.
I don't think the newer TPMS systems need to be reset. The transducer in each wheel continuously sends the pressure to its local receiver. The computer just records what each receiver is telling it and warns if any pressure falls outside limits. I believe most manufacturers have now standardized on 433MHz for the frequency and a common protocol for the message, which makes third-party sending units feasible. I sure hope so, as my new winter wheels are equipped with after-market transducers!
roadrutz is offline
post #8 of 13 (permalink) Old 11-11-2008, 08:44 AM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
TPMS is in the future for all of our North American cars eventually. The manufacturers need to perfect this technology. So far I've had no difficulties with system in my 2008 C-class.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #9 of 13 (permalink) Old 11-12-2008, 05:37 AM
Date registered: Mar 2007
Vehicle: 2007 Alpine Rain/Ash ML320 CDI
My tire pressure warning goes off at 27 PSI, or if I don't remember to check the air pressure regularly before the first freeze arrives. That also happens to coincide with my wife having the car out of town and panicing because it lights off in the morning when she has an early meeting and is running late.
CJzBenz is offline
post #10 of 13 (permalink) Old 11-12-2008, 07:32 AM
MB-SV's Avatar
Quoted: 77 Post(s)
Yep, as it should because 27 PSI is way too low and compromises safe handling, stability, braking, and tire life.
S.
MB-SV is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Tire Pressure Warning Came on...need help Luke! 5IVE The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 12-04-2007 08:18 AM
Low tire pressure warning and can't shift into Park ARIDAN W164 M-Class 3 02-17-2007 07:33 AM
Has Anyone Ordered the Tire Pressure Loss Warning System?? NewMB R171 SLK-Class 15 08-05-2005 04:41 PM
tyre pressure loss warning system rusper R171 SLK-Class 6 05-27-2004 11:17 AM
Tire Pressure Warning System Jörg W163 M-Class 6 03-22-2002 04:39 AM
