» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 10-08-2008, 01:51 PM   #1 (permalink)
Yazovets!'s Avatar
Date registered: Feb 2006
Vehicle: 2008 ML320 CDI
Exclamation MTEC H7 4500K HID Installed on 2008 ML320 CDI
MTEC H7 4500K HID Installation Guide on 2008 ML320 CDI
First off, I'd like to point out that this conversion kit will work on all 2006, 2007 and 2008 MLs, regardless of model number.
The kit is by MTEC which is a Japanese company. Maruta is their full name I think. The kit ships out of Taiwan.
A word about the ordering process. Only get the kit from the eBay member auto-perfect. He always has 1 or 2 of these kits on sale. Here are some of his current auction URLs:
eBay Link One
eBay Link Two
The kit is priced at $340 US but in the auction you can make an offer instead. I made an offer for $315 which was accepted. Shipping is $35 in the US and $40 international. For Canada, you have to pick the $40 option. Full insurance is available for $5 more which I took. The kit took 2 business days to arrive at my door, plus a $21 customs brokerage fee to FedEx.
Upon ordering the kit and paying, make sure to let him know in the "payment comment" box what color temperature you're looking for. You can get 4500 Kelvin, 6000 and 8000. 4500K is closest to OEM levels. 4500K puts out the MOST lumens and light on the road. 6000K is more of a blue color, but it puts down less light. 8000K is bordering purple, and that actually puts out less light than stock halogens on the road. I always recommend picking a color in the 4000-5000K range.
The ballasts are made in Japan. The bulbs are General Electric, so everything is quality stuff.
When you get the kit, you will get a variety of wires and parts.
To begin with, let's recap conceptually how this kit works. The bulbs go into the headlight modules obviously. However, the xenon bulbs receive power from the ballast. The ballast, in turn receives power from the ML's original H7 bulb connector. Therefore, we first need to prep our bulbs.
You will notice that the bulb has two wire ends each with a far plastic connector. There is also a rubber grommet halfway along those wires. Then the ballast itself has a single, far rubber wire. And finally there's a separate wire inside a black ribbed tube. Here it is:
So, let's prep the bulbs. We need to use the "black ribbed tube" wire in order to connect the ballast to the ML's H7 connector. On one end, this special wire has two terminals with gold prongs attached. On the other is a plastic connector. We need to shove the gold prong end THROUGH the rubber grommet so that it comes out next to the bulb itself. The gold prongs will reside INSIDE the headlight cover.
You will notice that the rubber grommet already has these two holes drilled into it. Since the gold prongs are wide, use a knife to widen these two holes so you can shove them through. It should like this:
Next, we have to actually attach an H7 male connector to those gold prongs. This will plug into the ML's H7 female connector which previously powered the halogen bulbs. MTEC supplies us with two pink connectors. The connector has holes to put the prongs into, see? When you look close, the prongs have a slight "lip" which locks them into position into the connector when you stick them in. So put those in, with the lips facing each other, inwards. You will hear them click if you did it properly.
Here's what your new male connector is supposed to look like. And also, check out the general scheme of connections.
If you've ever worked with the ML's halogen bulbs, you will know that the metal retaining clips are terrible to work with. Furthermore, they will NOT fit ANY aftermarket xenon bulb without modification. Luckily, MTEC supplies us with a new specially-formed clip for each side. It only goes on one way and it will look like this:
OK, now go downstairs to your car and install everything. The ML has these round headlight back covers which you gotta twist off first. You will notice that since we will be running wires THROUGH this, you cannot install the back covers simply. You will have to drill a hole between 23 and 25mm in diameter so that the rubber grommet from the bulb will be your insulation. For now, you can safely run the headlights without the back covers. Headlight condensation in the inner bottom part may happen but there is no danger - it goes away in 2 minutes. I will write up a further piece about the back cover drilling. My equipment is at the cottage, so I haven't done it yet. Be careful not to touch the bulbs with your hands. It's OK if they touch metal or plastic in the process, but try not to knock them up too bad. You have some troubles with the driver's side headlight because it's cramped on that side, but they do fit properly with patience.
You should mount the ballasts somewhere in the engine bay. Don't use anything sticky because these get hot. The ballasts have two mounting holes. In the ML's engine bay you will find about 5 possible "grounding screws". Unscrew those and screw them back in with the ballasts. Here's where I mounted mine:
The halogen projector lens on the ML seems to be decent. Of course the light isn't spread out uniformly like with a true xenon lens, but it's looking good.
It seems my 2007 Toyota Camry SE V6 has a wider beam pattern.
Anyway, in the video you can see that there is no flickering and there are no "bad bulb" errors in the instrument panel.
Click here to see the short video.
Here is another video of the ML's lights igniting in the garage.
Here is a video of the ML coming up the garage ramp.
2008 ML320 CDI | Iridium Silver | Black ARTICO Leather | Premium Package (H/K Logic7, Parktronic, Rear Heated Seats, Rear Power Hatch, DVD Nav, 10-way Front Seats w/ Memory) | Backup Camera | Aluminum Running Boards | 4500K MTEC Low-beam HID | 30% Metallic Tint | Boomerang2 Recovery System | Weathertech Front Floorliners | Bridgestone Blizzak DM-V1 Winter Tires
Yazovets! is offline   Reply With Quote
Old 10-08-2008, 03:02 PM   #2 (permalink)
Date registered: Apr 2008
Very nice! Where did you got the Kit? How much did it cost you? I want to get one but I'm not sure if it will affect the warranty. Also, did you had to do any drilling or is it just plug and play?
RaffN is offline   Reply With Quote
Old 10-08-2008, 05:11 PM   #3 (permalink)
MY2008ML350's Avatar
Date registered: Mar 2008
I'll be waiting for your instructions and parts list. Thanks in advance. I'm really thinking about doing this but I'm just concerned about losing my warranty. What's your opinion? (BTW, my ML is not even a year old).
2008 ML350, Obsidian Black, Premium Pkg
2008 C300W Sport, Calcite White, COMAND NAV, 7G-TRONIC
2007 C230W Sport, 040 Black,Prem Pkg,7G-TRONIC (gone)
MY2008ML350 is offline   Reply With Quote
Old 10-09-2008, 01:16 AM   #4 (permalink)
C-Rod's Avatar
Date registered: Oct 2002
Vehicle: 2010 ML350
Thumbs up Looks nice..............
l too, am interested in doing this...in the end, l should have just looked harder to find a newer M-Class with the options l wanted, but l was pressed for time, because l had a rental, and l was waiting for my claim cheque...l won't make that mistake again, when l purchase my next M-Class in a few years from now...Though to be honest, l do "love modding"....it keeps me busy....
1999 : Black Opal ML 430 : 125,000 KM (traded-in)
2002 : Bordeaux AMG ML 55 : 130,000 KM (traded-in)
2006 : Silver lridium ML 350 : 53,000 KM (stolen)
2006 : Cubanite Silver ML 350 : 60,000 KM (traded-in)
2010 : Tenorite Grey ML 350
C-Rod is offline   Reply With Quote
Old 10-09-2008, 09:27 AM   #5 (permalink)
Yazovets!'s Avatar
Modding is very fun! Especially when it all goes as planned. C-Rod, I love the Cubanite Silver color very much actually. I was in the market for a used, low-mileage ML320 CDI since the beginning of summer. Almost sealed a deal on a Cubanite Silver 2007 car but the dealer starting acting "gypsy" on me - kept on asking me to increase my offer without telling me their bottom line price. I walked out of that one based on principle.
Anyway, the complete write-up will be up this evening for you guys.
The kit is the MTEC one from eBay. The auction either allows you to buy it for $340 or make a "best offer". I offered the guy $315 and he accepted. It took two business days to arrive from Taiwan. The parts themselves are made in Japan, while the bulbs are made by General Electric. FedEx charged me $21 in customs brokerage fees.
Everything which you need is in the kit, so no need to buy anything else.
Here a link to the kit on eBay.
Don't worry that it says 2006-2007 only, and that ML320 CDI isn't listed. It works perfect on my 08 ML.
As for warranty, strictly speaking if something goes wrong, my headlights will not be covered. However you can reverse the conversion and put back the halogens in about 10 minutes if you really need to, so I don't think it will ever come to that.
Everybody has their own limits, but I'm personally OK with voiding the warranty on a component which I know how to service myself. My ML is less than a year old as well. I did a HID conversion on my Camry as soon as I got it, too.
Old 10-09-2008, 03:46 PM   #6 (permalink)
Yazovets, Thanks for the info! I was also thinking of reversing the conversion (before taking it to the dealer) if there is anything wrong with the car. I was thinking more like, IF they would check on my mods and log it when I take it in for service so when there is any problems they can pull out the log and say that the warranty is void for that purpose.
Old 10-09-2008, 04:46 PM   #7 (permalink)
Does that mean you have to reverse the conversion prior and everytime you're bringing it for service ? What a nuisance.
Anyway, I only hope I will only bring the ML for the regular yearly service and not for anything else..
Old 10-09-2008, 04:50 PM   #8 (permalink)
Originally Posted by Yazovets! View Post
..Here a link to the kit on eBay.
Hi Yazovets, link is not working, can you pls. post the actual URL? Thanks.
..Everybody has their own limits, but I'm personally OK with voiding the warranty on a component which I know how to service myself...
Will you help me if I ran into trouble doing my mod ?
Old 10-09-2008, 08:20 PM   #9 (permalink)
Yazovets!'s Avatar
Personally I have never had any troubles with bringing in a modded car to the dealer as long as the mods "worked". Same thing with my Toyota - it's heavily modded and I've been to two dealers MANY MANY times. They MAY write down in the system that you have certain mods, and decide to use it against you should these fail, yes. But that's only if you ask them to fix what you modded.
No, reversal is NOT needed at all. As I said above, as long as the mods work, you're fine.
Yes I can help you. Try the new links I posted at the thread's start. Or try searching on eBay for "MTEC W164". Or here are the direct ones:
http://cgi.ebay.ca/MTEC-HID-KIT-4-MERCEDES-BENZ-ML350-ML500-ML63-AMG-W164_W0QQitemZ360095651982QQcmdZViewItem?hash=item 360095651982&_trkparms=72:1215|39:1|66:2|65:12|240 :1318&_trksid=p3286.c0.m14
http://cgi.ebay.ca/MTEC-HID-CONVERSION-KIT-MERCEDES-W164-ML350-ML500-ML63_W0QQitemZ120314770439QQcmdZViewItem?hash=item 120314770439&_trkparms=72:1215|39:1|66:2|65:12|240 :1318&_trksid=p3286.c0.m14
Setup guide is now live!
Old 10-10-2008, 07:21 AM   #10 (permalink)
Solidjake's Avatar
Date registered: Feb 2008
Vehicle: 99 ML430 - 02 330i
Send a message via AIM to Solidjake
wooo, logitech z-5500's. i got the same and i love them!
nice lights btw, great write up too
Solidjake is offline   Reply With Quote
MTEC HID KIT 6000k vs STOCK HID 04 LS430 germyko W211 E-Class 2 12-02-2008 07:30 PM
Has anyone installed the MTEC or the K1 motorsport HID? inspirational W163 M-Class 9 11-25-2007 09:16 PM
Anyone installed aftermarket HID kit (Mtec or McCulloch) us_matrix W211 E-Class 2 09-19-2007 06:54 PM
City lights are in, need HID color recommendations...4500k or 6000k? deyainrdy4ds W208 CLK Class 7 08-14-2007 12:13 AM
Just installed the MTEC H3 HID Super White Fog Light Bulbs Benza W163 M-Class 18 02-17-2003 12:44 AM
