3-zone climate control.... - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-07-2008, 12:47 AM Thread Starter
C-Rod's Avatar
Date registered: Oct 2002
Vehicle: 2014 ML350 BlueTec
Question 3-zone climate control....
it was quite cold up here last night around -1 Celsius, so when l was leaving work around 2:15 in the morning, and turned on my climate control, l always use the auto button, but it only shows the auto light and temperature, but not the fan speed on the unit, and l had a devil of a time with my windows fogging up on the inside. Am l missing something ???? Do l manually have to raise the fan speed ?????
1999 : Black Opal ML 430 : 125,000 KM (traded-in)
2002 : Bordeaux AMG ML 55 : 130,000 KM (traded-in)
2006 : Silver lridium ML 350 : 53,000 KM (stolen)
2006 : Cubanite Silver ML 350 : 60,000 KM (traded-in)
2010 : Tenorite Grey ML 350 : 20,000 KM (traded-in)
2011 : Chromite Black Grand Edition ML 550 (traded-in)
2014 : Palladium Silver ML 350 BlueTec
C-Rod is offline
post #2 of 5 (permalink) Old 10-07-2008, 08:50 AM
dragonrpc's Avatar
Date registered: Aug 2004
Vehicle: 2007 ML63 AMG
Shouldn't have to, the fans should flucuate accordingly by setting the desired tempeture. Another tip if you hit the auto button again, it will show you what the current air flow (red lights around the command unit) and I believe this is so you can 'adjust' some of the auto settings. I can't remember if it shows the fan speed with that
龍 Dragon's 2007 ML63 /////AMG
22" HRE 647R, 40mm LM, PowerChip, HID Head/Fog(6k) Lights, Red Calipers, Painted Side Markers, Stealth Blinkers.
dragonrpc is offline
post #3 of 5 (permalink) Old 10-07-2008, 11:49 AM Thread Starter
C-Rod's Avatar
Thumbs up Thanks "D"............
l will try that tonight............The cold weather is coming.......
C-Rod is offline
post #4 of 5 (permalink) Old 10-09-2008, 12:23 AM Thread Starter
C-Rod's Avatar
Just a follow-up..........
l'm just trying to get use to this 3-zone climate control unit, as l had the 2-zone before, it was a fairly easy modification...l found the front and rear unit on E-bay for a song, and both were plug and play....My son enjoys choosing his own temperature in the rear...
C-Rod is offline
post #5 of 5 (permalink) Old 10-09-2008, 04:12 PM
MY2008ML350's Avatar
Date registered: Mar 2008
I really like the 3 zone climate control, my wife likes hot (front passenger) , my daughter (at the back) likes moderate and I like cold - driving...
2010 B200, Polar Silver, Premium Pkg
2008 ML350, Obsidian Black, Premium Pkg
2008 C300, Calcite White
2007 C230, 040 Black, Premium Pkg (gone)
MY2008ML350 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    2 Zone Climate Control NBehm W251 R-Class 1 04-07-2008 05:24 AM
    3-Zone Climate Control Package block11 X164 GL-Class 11 02-11-2007 11:24 PM
    3-Zone Climate Control no longer being built... abscam X164 GL-Class 11 01-12-2007 11:21 AM
    dual zone climate control vs. single zone tresean1 W202 C-Class 4 10-02-2005 02:45 PM
    climate zone control bulb replacing??? vballbach R170 SLK-Class 4 12-06-2004 09:25 AM
