Brake Lamp Error - Substitute Bulb On - Mercedes-Benz Forum
post #1 of 22 (permalink) Old 10-03-2008, 09:52 AM Thread Starter
Date registered: Oct 2008
I have a '06 ML350. Just got it back from the dealer for some other work when it has started displaying a new error.
The error cycling through says "Brake Lamp - left substitute bulb on" then "Brake Lamp - right substitute bulb on".
On researching the error, apparently when the substitution is done, it's done to both bulbs, which makes sense since both bulbs going out simultaneously sounds unlikely.
Are the bulbs end-user replaceable? If so - can someone help with directions on how to access/open the tail light assembly?
thanks.
mickydfw is offline
post #2 of 22 (permalink) Old 10-03-2008, 09:57 AM
MB-SV's Avatar
Date registered: Nov 2007
Quoted: 77 Post(s)
thanks.
Unfortunately this is a common problem with the ML and other Benz's too. Talk to your dealer service about this. As long as your brake lights are still functioning (you should check), you can wait unit your next service. My 06 had this problem and a brake light assembly was replaced and several bulbs.
S.
2013 Mercedes C250 Sport package PLUS steel gray metallic/black
2007 Lexus IS350 Sport package smoky granite mica/gray (+F-Sport, etc.)
2010 Honda Civic GX (CNG) white/tan
MB-SV is offline
post #3 of 22 (permalink) Old 10-03-2008, 01:52 PM Thread Starter
Thanks MB-SV.
Is that brake light assembly replacement considered warranty work or out of warranty?
mickydfw is offline
post #4 of 22 (permalink) Old 10-03-2008, 03:13 PM
MB-SV's Avatar
Quoted: 77 Post(s)
Thanks MB-SV.
Definitely a known warranty issue.
S.
MB-SV is offline
post #5 of 22 (permalink) Old 10-04-2008, 09:13 PM
Yazovets!'s Avatar
Date registered: Feb 2006
Vehicle: 2014 ML350 Bluetec
Quoted: 2 Post(s)
You don't happen to live in Toronto, Canada like me, do you? Today I saw an ML350 and its rear fog was being used as the brake light. I guess his car was using substitutes like yours...
2014 ML350 Bluetec | Teronite Grey | Black ARTICO Leather | Premium Package | Bi-Xenon Package | Driving Assistance Package | Weathertech Floorliners & Trunk Mat
Past: 2011 ML350 Bluetec, 2011 E550, 2008 ML320 CDI, 2004 ML500
Yazovets! is offline
post #6 of 22 (permalink) Old 10-05-2008, 11:16 AM
MB-SV's Avatar
Quoted: 77 Post(s)
Not likely, when in "substitute" mode, brake lights on both right and left sides work in a legal and proper fashion.
S.
MB-SV is offline
post #7 of 22 (permalink) Old 10-05-2008, 12:48 PM
Date registered: Jun 2008
Vehicle: 2008 Mercedes Benz ML 320 CDI
happened to me on my 2008, drivers side brake light i just replaced it myself, was not too impressed changing a bulb this early
AbzKarim is offline
post #8 of 22 (permalink) Old 10-05-2008, 01:26 PM
MY2008ML350's Avatar
Date registered: Mar 2008
When was your 08 ML delivered? I will not be impressed either if that happens to me (fortunately, mine is fine). That should be covered by the 1 year bumper to bumper warranty but if you can change it yourself quickly, probably you didn't bother to go to the dealership.
2010 B200, Polar Silver, Premium Pkg
2008 ML350, Obsidian Black, Premium Pkg
2008 C300, Calcite White
2007 C230, 040 Black, Premium Pkg (gone)
MY2008ML350 is offline
post #9 of 22 (permalink) Old 10-05-2008, 05:02 PM
mine was delivered in february, and theres no dealership where i live, but replacing the bulb was simple
AbzKarim is offline
post #10 of 22 (permalink) Old 10-05-2008, 06:29 PM
MB-SV's Avatar
Quoted: 77 Post(s)
Maybe the Chinese bulbs given out in the Mercedes parts department will last longer.
S.
MB-SV is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
    3rd Brake Lamp Bulb replacement NEOKEN W210 E-Class 19 08-09-2009 08:36 AM
    Lamp Error Message Nor-Cal-CLK C208/A208 CLK-Class 6 08-09-2007 11:41 PM
    Lamp Error - Any Suggestions slybydesign W210 E-Class 8 06-06-2007 02:45 PM
    20" LED strip + LED brake lamp bulb video clips... Drew W163 M-Class 3 06-01-2002 08:27 PM
    Fog lamp bulb and brake pad replacement questions. Chris(LE) R170 SLK-Class 13 12-18-2000 04:34 AM
