Hi all - I have a 2006 ML350 (standard suspension and 17" wheels). I need new tires soon and would like to go with something wider that will fit on the OEM rims on my truck. Currently my tires are 235/65R17 and i feel they are too skinny for this truck
What is the widest (ok, may be not the widest, but a bit wider) tire size I can go with that will mount on the current rims?
Thanks
2006 ML350 Pewter/Ash, Trim Pkg, Sunroof Pkg, Entertainment Pkg, NAV, Heated Seats
_________________
2001 BMW 325i, Leather, Premium, Heated Seats, CD changer
Personally I just bought (but have not mounted) new Yokohamas to put on mine and kept the original size. Right or wrong I believe that larger tires/contact patch/weight may improve looks at the cost of some (probably minor) fuel economy. What I would recommend for you is to call the Tire Rack and talk to one of their specialists.
Thanks
i'm running the 19" gl 5 double spoke setup. 275 is how wide they are and it sticks just a mm or 2 out in the front. in the back it is still within the fender well
How expensive does gasoline have to get before you stop making modifications that will lower your fuel economy?
The notion Mercedes has specified "too skinny" tires is inane.
he isn't going to affect mpg by that much. maybe 2-3mpg at the most.
tires can be considered "too skinny" take for example the s class. the w140's standard tire width was 235/60/16. for the w220, they changed it to 225/something/16.
Purely for looks in this case. And (I genuinely ask) how much does a wider tire reduce efficiency? Obviously it adds friction- but with how much impact?
__________________ 2000 ML430
Chrome grille, tailgate latch, logo on rims, instrument cluster rings - K&N air filter - Ate brakes - projector style lights w/xenon bulbs - white LED lights on licence plate - handpainted pinstripe - designo Java Shift Surround
My preference is to stick with OEM tire-sizing. But the 17's are too small and no longer standard on the ML today. I threw away the 17's and upgraded to 19's and used the OEM-sized 255/50/19 tire, which is standard size on current ML. Just my 2 cents regarding preference. I noticed/calculated no measurable difference in gas mileage.
If you want to do it right, you are looking at different wheels (and you can still stay within OEM-specified sizing.)
Very little, if staying within range specified by the factory for 18" and 19" wheels. Frontal area increase probably has bigger impact than the friction, still not significant.
