Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 05-22-2008, 02:02 PM   #11 (permalink)
Date registered: Sep 2006
My experience with this spring has been mostly positive. Camber adjusted all the way out is still not within spec. Ride quality is hard to judge since I have 22inch wheels, but handling is much improved. I do notice some harsh clunk in the rear when going over small dips but that could be the combo of spring and tire size.
I do swap my tires front to front and back to back (staggered sizes) every 10k as the inboard part of the tire will degrade twice if not more quickly than outboard.
Cost was steep at 800 to install but was done at Brabus Claus Ettensberger shop in Newport Beach California.
07' ML 350 Obsidian Black
PO2 Premium Pkg.
319,322,922,819,550,220,901
04' Dodge Ram 1500 Hemi
90' Nissan 300zx Twin Turbo
kingtut(SoCal) is offline   Reply With Quote
Old 05-22-2008, 02:23 PM   #12 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
Thanks King-tut. I think that might qualify as a somewhat less than satisfactory experience given the harsh clunking and tire wear problems. But the 22's probably cause most but not all of the ride quality deterioration.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport granite metallic/gray
2004 Porsche 986S seal gray metallic/black/black
2002 Jeep KJ Sport white/gray
MB-SV is offline   Reply With Quote
Old 05-22-2008, 04:15 PM   #13 (permalink)
Date registered: Jul 2006
King-tut, do you have pics? Did you get the Eibach springs or the H&Rs?
davicon is offline   Reply With Quote
Old 05-22-2008, 08:09 PM   #14 (permalink)
The clunk as I put it is at low speeds and happens with and without cargo/passengers. I am satisfied with this spring. I did expect a harsher ride when lowering any car/suv. I took the family (4 + niece) to Sea World (120miles away)last summer, and with 5 passengers full cargo in back and a large cargo box on roof I had no sag in the back and the ride quality was impressive to me. I expected bottoming out and reduced handling but none of that happened.
Old 05-22-2008, 08:31 PM   #15 (permalink)
I have the eibach sport lowering springs.
[IMG][/IMG]
[IMG][/IMG]
Old 05-23-2008, 01:55 AM   #16 (permalink)
Nice. Your car looks sweet. Are those 22s?
Old 05-23-2008, 10:42 AM   #17 (permalink)
MB-SV's Avatar
They are 22's. Looks like they are staggered?
Old 05-23-2008, 10:45 AM   #18 (permalink)
MB-SV's Avatar
Looks great. Are those Toyo tires?
Old 05-23-2008, 11:08 AM   #19 (permalink)
MB-SV's Avatar
Kingtut - Thanks for the feedback on the springs, good info especially for those seeking a fairly radical setup (22" wheels, etc.). Ride quality for those on 22's is usually not a concern.
But for those of us with a more conservative setup (19" or 20" wheels) and using stock shocks, there will be a noticeable deterioration in ride quality caused by the combination of soft stock shocks and soft Eibach springs with limited suspension travel. Alpina (in earlier post) above did the back to back comparisons with a more conservative wheel/tire setup, and he noted the "annoying" ride change. Reduced handling and bottoming is not the problem fortunately. Although clunking unloaded/loaded and tire wear is not a plus either.
Old 05-23-2008, 12:37 PM   #20 (permalink)
Any time you change your springs or shocks or both (preferable) you have two choices. The choice I hear most people want is improved handling maybe lower ride height without sacrificing ride comfort, a hard combo to meet. Second choice (mine) maximum lowering, stiffer/tighter feeling (no floaty feel).
Our choice's for shocks and springs are very limited compared to other models and makes of car's/suv's. I have used Eibach on other cars I own and had good results with them, so I went with them over Brabus (pricey) and had not heard of anyone using H&R springs yet. I don't think the "sport" line of Eibachs are softer than stock. I don't know the stock lb rate for our ML's springs so I can't be sure.
I am a spirited corner taker and if I want straight line speed I drive my highly modified 300zxTT but when I get in my family car I still want it to handle in a tight firm way.
I would like to hear more on shock choices for our ML's as that could get rid of my "clunk" which happens 1 or 2 times a week.
Eibach and H&R lowering springs sets Richard / E320 W210 E-Class 4 04-07-2006 01:02 PM
Eibach and H&R lowering springs sets Richard / E320 The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 04-02-2006 06:48 PM
lowering with eibach springs arcane12 W208 CLK Class 3 07-12-2005 11:11 AM
Lowering Springs H&R or Eibach Hugo R170 SLK Class 12 04-28-2002 08:31 AM
Anyone selling their h&r or eibach lowering springs Guest (MBNZ) W202 C-Class 3 07-13-2001 01:01 PM
