Go Back   Benzworld.org - Mercedes Benz Discussion Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Old 04-19-2008, 01:13 PM   #1 (permalink)
Date registered: Dec 2006
Jerky Transmission SOLVED PROBLEM ML-350
Hi, As every body knows this is an old and very well known problem for most of ML-350 (mine is a 2007) I have my car since new, and since first day I noticed the jerky trans. Of course this is unacceptable for any brand new car and specially for a MBenz. After several visits to the dealer where they "tune" the Trans. and reprogram the computers, there were no satitsafactory results. I have to tell you that the dealer knows very well this problem in ML's before my first visit, but they explain me that they have to perform in the car this first steps I have explained before, and after this they may take a drastic solution. CHANGE THE VALVE BODY , but here comes the most important thing; there are two different valve bodies (maybe more than two). The original VBody and the new ones. Ofcourse MBenz knows the problem and they redesigned a new VBody. I live in Cuernavaca Mexico, and the dealer requested the Vbody to Germany, I had to wait 3 weeks before the spare parts come to the dealer, they performed the change and now my car is as it should have come from the factory absolutely smooth.
I wish and hope this helps to all the people with jerks problems. If your car is under warranty they have to change this without charge, if you are out of warranty is another story. (sorry for my english)
SCIANDRA is offline   Reply With Quote
Old 07-04-2008, 10:39 AM   #2 (permalink)
MBKing16's Avatar
Date registered: May 2008
Do you know the number for the new body valve?
MBKing16 is offline   Reply With Quote
Old 07-04-2008, 06:27 PM   #3 (permalink)
Date registered: Jan 2007
Vehicle: 2002 honda civic
every model has a different valve body. same part but different software. the slks has a 1206, e class a 1306 or 1806, new e class a 2106. the problem the dealers face is they cant just put a valve body in it even if there is a newer number. and they cant just change it cause you ask. i know that it usually fixes the issue, but dealers have to flash the control unit first, try adapting the gears before a valve body can be done. and they have to be authorized by mbusa before they can be done.
Streetglower is offline   Reply With Quote
Old 07-05-2008, 12:11 PM   #4 (permalink)
Premium Member
AZ.Benz's Avatar
Date registered: Feb 2008
Vehicle: 2008 E320 BLUETEC
Premium Member
Buen hecho! Por supuesto era un mexicano con el soluccion! Andale pues...suerte! Yo tambien tengo problemas de jalarmela. jajajaja
AZ.Benz
AZ.Benz is offline   Reply With Quote
Old 07-06-2008, 06:16 PM   #5 (permalink)
MBKing16's Avatar
So even though I live in Canada My dealer ship STILL has to check with MBUSA? So then, what is the Valve body number for the new ML Suvs'? I have a 06 ML 500, which valve body is required for that then?
Last edited by MBKing16 : 07-06-2008 at 06:18 PM. Reason: Needed to input more information
Old 07-09-2008, 03:22 PM   #6 (permalink)
MB-SV's Avatar
Date registered: Nov 2007
I have an 06 ML350. My tranny works fine almost all the time. Sometimes I get a rough shift from 2nd to 1st gear, but not often enough to justify a fix. Since I have another couple of years on the MB warranty, I'll monitor and see if it gets worse.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport granite metallic/gray
2004 Porsche 986S seal gray metallic/black/black
2002 Jeep KJ Sport white/gray
MB-SV is offline   Reply With Quote
For those who HAVE/HAD the jerky Transmission 3FIFTY W164 M-Class 24 07-03-2007 09:05 PM
Transmission jerky bullockandrew R129 SL Class 9 04-26-2007 01:37 AM
transmission vacuum supply problem solved p100 W126 S,SE,SEC,SEL,SD,SDL Class 1 03-11-2007 10:17 PM
Jerky Transmission rkonster W163 M-Class 1 09-05-2004 08:48 AM
Jerky transmission Guest (MBNZ) W210 E-Class 1 10-04-2002 01:51 AM
