Have you ever wanted to use the horn at times but can't ? Since it is electronic, horn won't work if the key is not engaged. Although I don't use it as much (except honking on those crazy drivers on the road), at times I need it, say for example you dropped the wife in the grocer and by the time she gets back out, you'll need to call her attention while you're parked somewhere. What do you think?
Reason: spelling
I never noticed this, since I only use the horn when the car is running.
S.
2008 Mercedes C300 Sport mars red/black
2007 Lexus IS350 Sport granite metallic/gray
2004 Porsche 986S seal gray metallic/black/black
2002 Jeep KJ Sport white/gray
All horns are "electronic." It's how it's wired that makes the difference and the Bosch standard used by German car makers specifies they only work when ignition is on--yes, unlike some American cars.
Kent Christensen
Albuquerque
'07 GL320CDI, '06 E320CDI
Thanks for the "electronic" clarification. So why do you think German cars' horns were not wired to operate unless the key is in the on position?
I have the same question as to why American car's gas tanks are in the passenger side while Japanese cars are in the driver's side.
It's generally considered to be safer to have the gas filler on the passenger side, per the safety experts.
"M".....if you ever run out of gas, and you are stuck on the highway, you can fill it safely on the passenger side, without fear of getting hit by a car or truck on the driver's side.......
1999 : Black Opal ML 430 : 125,000 KM (traded-in)
2002 : Bordeaux AMG ML 55 : 130,000 KM (traded-in)
2006 : Silver lridium ML 350 : 53,000 KM (stolen)
2006 : Cubanite Silver ML 350 : 24,000 KM
